well just look what happened to me
Discussion in 'General Maverick/Comet' started by sam03rc, Oct 28, 2010.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    i have no clue what could of caused this or for the throttle to get stuck wide open when i finally got it started
    it just all confuses me.
  2. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    Your problem sounds like more than just the water pump. The water pump damage might be the result partly of the throtle staying wide open. Check the throtle spring and linkage for breakage or loose parts. Good luck.
  3. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    I may have a non grabber hood . I will have to check it to see the condition of it.I am about 150 miles west of You .
  4. Mavaholic
    I have a rusty hood that is pretty bad on the inside but the outside sheet metal aint bad at all. You can have it. I will be going to my daughters in Camden NC for Thanksgiving and pass through Chesapeake. I could hook up with you somewhere if you want it.
  5. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    October must be a bad month for water pump housings. The same thing happened to a '73 Maverick I had at the time on October 24, 2004. Fortunately, my hood was up and I only had to replace parts and not sheet metal.
    http://mmb.maverick.to/showthread.php?t=11068&highlight=water+pump
    Sorry, pictures have been removed for a long time.
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Good thiing you weren't leaning over the fender when it let go.
  7. sam03rc
    sam03rc Member
    gates county, nc
    yea that could of gone totally bad thats why after this im getting an electric fan never really thought how dangerous they could be if it got off somehow and if someone was near it who knows what could happen.
  8. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Your damn lucky your head wasn't not under the hood when all hell broke loose...
    Your problem could be a fan out of balance
  9. Dfitzman
    Dfitzman Member
    Taxachusetts
    1971 Green Machine
    hmmm after seeing this and almost loosing a couple fingers earlier this summer on my 200 UNSHIELDED fan blade. I might do the taurus fan upgrade when I drop in my 302. I'll tell ya THAT woke me up was leaning in to adjust timing and the tips of two fingers just touched the blades and went ta-ting ! I had forgotten it was wide open. :mad:
    No damage whatsoever but we all know what could have been.
  10. PaulS
    It looks to me like the motor mount is bad. He fired it up, the engine torqued over locking the throttle wide open and the fan hit the hood- broke the pump and into the radiator.
    Cables aren't suppose to lock up like that but I have seen it happen.......
  11. lika
    lika SeƱor Comet
    IA
    comet 71
    hooo mannnn
  12. sam03rc
    sam03rc Member
    gates county, nc
    dude that makes a ton sense now that i think of it cus they are the stock motor mounts from what i know of. ill have to check them when i start fixing it thanks paul explains why i have so much damage to my hood hmmmmmm
