What a Diffrence a Driveshaft Makes
Discussion in 'Technical' started by hacksaw415, Jan 16, 2009.
  1. baddad457
    I think you've confused this scenario with another. If the U joint cross pins aren't lined up with one another (talking about from opposite ends of the driveshaft) you will get a vibration that's exactly like what you get with a bad u joint. We've got two International trucks at work that both suffered from this. The rear driveshaft on both were one tooth off on the slip joint splines putting the cross pins off. Both had a noticeable vibration at highway speeds.
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I've had vibrations before and turning it 180 fixed it..
    I thought it was a wifes tale as Frank suggested earlier, but it fixed the problem. I've never marked a driveshaft either when removing it, but I was told to flip it 180 after I said I had a vibration and it fixed it.
  3. 71gold
    does anyone have this in a...repair manual...:huh:
    most likely the cups weren't seated in the yoke, when you flipped it you seated them....:yup:
    ...my unmarked driveshaft is laying on the floor ready to be installed...
    when i get it back together and running, i will rotate it 180 and see if it makes a difference...
    ...Frank...
  4. Andysutt
    Conway Arkansas
    1972 Comet GT
    I haven't seen it in a repair manual, but I have seen it mentioned before to mark them IIRC. I'll look that up in a few minutes.
    I've never seen a yoke seat so easily to be honest with you either. When I flipped it all I did was unbolt the u-bolts, spin it w/ the transmission in park and bolt back up. I never removed it from the transmission, so it didn't get bumped around.
    It struck me as odd also why this fixed it, but it did.
  5. Andysutt
    Conway Arkansas
    1972 Comet GT
    Update:
    just looked in the Haynes for my Sonoma and Jimmy.
    Driveshaft Removal:
    *Raise the vehilce and support it securliy on jackstands. Place the transmission in neutral with the parking brake off. Block the Front Wheels to prevent the vehicle from rolling.
    * Using a scribe, a hammer and punch, or paint, make marks on the drivehsaft and the differertial flange in line wth each other. This is to make sure the driveshaft is reinstalled in the same position to preserve the balance.
    So, maybe it's not a wife tales?? Who knew.
    If anyone wants me to scan the page I can.
  6. 71gold
    yes...scan it please and put it in the...tech. section...driveshaft removal/replacing...(y)
    AFF...:yup:
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    Will do ;)
    ..FFA..
    I'll just scan that one part of it... I dont want to be violating copyrights ;)
  8. Andysutt
    Conway Arkansas
    1972 Comet GT
  9. baddad457
    If anything, it's to preserve the wear patterns developed over time with the driveshaft and rear differential. Not the balance. Rear differentials aren't balanced that I know of. The brake drums are the only part of an assembled rearend that are. It would make no difference with a new setup, other than if you did have a vibe, it could help to flip it, that would be a 50/50 shot at a fix though.
  10. Andysutt
    Conway Arkansas
    1972 Comet GT
    I'm going by the book, and that is exactly what it says, so I posted it
    The ring/pinion has to be in somewhat of balance also, whether they balance them or not is another story.
  11. baddad457
    The ring and pinion are swimming in gear oil, that in itself will absorb any vibes they make.
  12. baddad457
    Not saying the book is wrong, but the two assemblys as a whole aren't balanced as far as I've ever heard of at the factory.
  13. Andysutt
    Conway Arkansas
    1972 Comet GT
    While that is true, they still have to be somewhat balanced to start with.
    I'm not going to argue about it, just saying it has to be somewhat close to start with or just the gear oil wouldn't soak up all the vibrations.
    And there's a reason they put that in the Haynes manual, and the word "balance" instead of "wear pattern"
  14. Andysutt
    Conway Arkansas
    1972 Comet GT
    I agree with that. Never heard of the being balanced at the factory either. :thumbs2:
  15. rthomas771
