What are my options for a 9" rear axle swap on a 71 comet?
Discussion in 'Parts Interchange' started by cardstars, Sep 1, 2011.
  1. 74bronco
    74bronco Member
    willamette valley ,oregon
    73 comet , 74 bronco
    a often over looked but rare option is a 9" rearend from the edsel wagons my grand father collected edsels and we used the rearends from the wagons for a couple 67 stangs and were able to fit d50 rubber with no mods . just another thought !!
  2. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    You are correct the edsel Wagon used the same rear as the ford wagon so it would be a nice fit under a 67-70 mustang.
  3. rthomas771
    The '63 Falcon V8 was 1/4" shorter than a Maverick. :yup:
  4. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    I just got a reply from K&K motors out of Texas they have one from the Lincoln Disc brakes and all for 500.00. I hapen to be shoping for one for my 71 mav. I have found a few all around the 500 range.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I paid $300 for mine with a new set of 4.30's and a mini spool. The spool needs to find a new home but other than that I think it was a good deal.
  6. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    I would take that in a hart beat! Anything I get will most likely get a different chunk (or new guts anyway).
  7. baddad457
    I bought a narrowed housing with forged bearing ends on ebay for about $100-200 (don;t recall the exact price) Bought a complete 81 Bronco 9 with 3.50's, trac loc and 31 spline axles for $150, new Strange axles (with bearings installed) for $400. Had to later replace the pinion bearings and races, that cost another $50 or so. Add the cost of the new brake shoes and drums for the Bronco brakes. All in all this cost me just about $900-1000.
  8. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    For what you got ? that is a great deal I guess all you gota do is shop and have a little luck. I just want a 9 I don't have to narrow I can deal with an inch or so, with my minitub plans and some offset I'll be good to go. A posi chunk with good gears would be a bonus.
  9. baddad457
    He left out the drum brake 9 that was used in some 74-80 Granada's and Monarchs. I've seen two of these, both were in 1980 Granada's. The disc brake 9 was an option in the Granada and Monarch. The first "Versailles" 9 I bought, was pulled out of a Monarch. Since then, I never pass up any of those cars without looking under them to see what's there.
  10. jmgford
    jmgford Member
    Iowa
    I made this corrected copy several years ago and keep it on a Word document. That chart has spread over the net for many years and is filled with errors. The incorrect, incomplete, or misleading items are in red and the clarifications are in blue.
    Ford 9-inch Rear End Data
    Year & Model Axle Length
    65-66 Mustang 57.25 inches
    63-65 Fairlane 57.25 inches
    67-70 Mustang 59.25 inches
    71-73 Mustang 61. 25 inches
    77-81 Versailles 58.5 inches
    77-80 Versailles 58.5 inches
    67-73 Mustang, Torino, Ranchero, Fairlane 59.25 inches to 6 1.25 inches
    66-69 Fairlane, Torino 59.25 inches
    70-71 Torino 61.25 inches
    57-59 Ranchero and station wagon 57.25 inches
    66-77 Bronco 58 inches
    77-81 Granada/Versailles 58 inches
    75-80 Granada, Monarch, Versailles 58.5 inches
    67-71 Comet, Cougar, Mustang, Fairiane 59.25 inches
    66-69 Comet, Fairlane, 67-70 Mustang, Cougar 59.25 inches
    71-73 Mustang 61 .25 inches
    64 Falcon 58 inches
    64-65 Falcon 57.25 inches
    67 Fairlane 63.50 inches coil springs
    No such car as a coil spring rear '67 Fairlane
    72 Ford Van 3/4 ton 68 inches
    73-86 Ford Van 3/4 ton 65.25 inches
    57-59 Ranchero and station wagon 57.25 inches narrowest 9" housing
    66-77 Bronco 58 inches 5-on-5 1/2 inch diameter bolt circle
    67-73 Torinos, Rancheros, Fairlanes 59.25 inches or 61. 25 inches
    See above specs
    67-71 Comets, Cougars, Fairlanes 59.25 inches
    67-69 Comets, Fairlanes, 67-69 Cougars 59.25 inches
    75 Mustang II 8" 57.00 inches
    74 Maverick 8" 56.5 inches
    70-77 Maverick, Comet 8" 56.5 inches
  11. fastmerc
    fastmerc Member
    Santa Clara CA
    Bits and Pieces!
    Don't waste your money!
    Go with the Crown Vic disc brake swap onto your 9" or 8" housings and save yourself cash and unsprung weight!
    I've done the Versailles thing and had I known what I know now about the Crown Vic swap (see Technical section thread) back then, I never would have messed with that heavy expensive piece of steel! ( I believe the housing is about 25-40lbs heavier than stock piece!) Versailles gear ratios are always horse crap scrap too! Rarely do you see even a 3.00!
    The bearings are from an F250 truck, and all of the brake pieces (rotors, seal kits, pistons) are now made of unobtanium! Including the flex lines!
    If the 'Vic brakes will haul down a Highway Patrol car or Taxi from cruising speed....imagine what they will do in a lightweight car like these?!
    Cheers!
    Steve
