What are you guys running for a brake set up?
Discussion in 'Drag Racing' started by mgabski, Jul 13, 2016.
  1. mgabski
    mgabski Member
    1973 Maverick
    I made my first pass in my car in a while yesterday and while the et wasn't exactly scary, the slowing down part was. I have a 73 with disc fronts and drum rear. I am thinking I may have some air trapped in the lines so I'm gunna try and bleed it, but I just wanted to see what everyone else is running. I'm just running factory stuff for now.
  2. z28th1s
    Lynchburg, VA
    My '72 Grabber is still running the stock 4 wheel non-power drum brakes. Our '75 Comet GT has the stock style non-power front disc/rear drum setup. The Comet GT stops much better than the Grabber!
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Maverick Front discs.
  4. pro stock
    pro stock Member
    1973 maverick
    My 73 is still running non power drum brakes on all 4s it's been 6.36 @108mph in the 1/8 it stops ok
  5. Rick
    Rick G8I operations
    Ocala, Florida
    Modern disks in front, drum rear seems to slow down okay at 137 plus.
  6. mgabski
    mgabski Member
    1973 Maverick
    So I'm guessing I most likely still have air in the system. I only trapped 106. But it didn't feel like I had enough track left to slow down. Gunna try to bleed them more this weekend and see if it improves. All brake components have been replaced within past 4 years and it's an occasional driver so not a whole lot of use on them.
  7. bb466
    bb466 Member
    west virginia
    72 Mav
    Wilwood all four corners here.
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    There must be something up there because that combo should do much better for this application in a lighter car. I've run MUCH faster than that with 4 wheel drum setups in the past and the initial bite torque on drums is actually very good. But where they really suffer is the quicker heat buildup/fade that comes from max effort and/or repeated stops.. none of which should really apply here.
    Also be sure to pull it all apart for cleaning/inspection and make sure you have no fluid weeps from any of the wheel cylinders. Light rust and brake dust buildup will usually hurt you a bit there too. Clean the machined surfaces and scuff the pads to freshen it back up to new and then bleed the lines.
    Crazy Larry likes this.
  9. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    Factory disks up front 96 crown v disks on back. does ok trap speed 115.
  10. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    I'm running factory manual front discs and drum rears. Not the best for short stopping distance, but it stops straight and there are no surprises on the initial hit at 110 mph. That initial hit is the most important factor for a drag car, IMHO.
    A LONG time ago I used to race a Brand X '55 with only back drum brakes. Didn't stop very well, but it stopped straight.
  11. mgabski
    mgabski Member
    1973 Maverick
    I bled the front a few different ways. Unfortunately the bleeder screws are not in the best shape ,so couldn't get the rears open. The hex portion on all were rounded. With this system not being super old, I want to put new bleeders in. Does anyone know the correct replacement ones? I got a much better pedal after bleeding but I think I can do better still
  12. 71gold
