  1. bradmosley
    bradmosley Member
    Pencsacola, FL
    73 Maverick
    carb
    today i tried getting my carb straight again. not sure if it is just that or the pump too. only get to work on it in the cold evenings. hopefully its my fuel pump beCAUSE I RECENTLY rebuilt the holley. it just starvs for fuel when i accelerate.
  2. bmcdaniel
    When you first give it more pedal or when the engine tries to rev?
  3. bradmosley
    bradmosley Member
    Pencsacola, FL
    73 Maverick
    every time i give it gas....idles great....i just read through many threads about white smoke too and am going to replace the modulator because i am losing tranny fluid..maybe this is also making it run like crap...plugs are fouling (2sets in 1 month or so) the plugs are black and they all have oil on the threads
  4. bmcdaniel
    I would suspect the accelerater pump / squirters aren't getting fuel. If you reversed the bowl gasket the hole that supplies fuel from the pump to the squirter will be blocked. Did you properly adjust the pump lever arm after reassembly?
  5. bradmosley
    bradmosley Member
    Pencsacola, FL
    73 Maverick
    accel pump
    not sure where to adjust the lever. Sooo. Nope... You got the know how
  6. kafrompa
    kafrompa Member
    Cedar Creek, Texas
    1971 Comet, 2006 FiveHundred, 2007 Focus and 2008 Ranger XLT
    final QA
    Did you check the float function and float level adjustment?
  7. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    Got my Rack&Pinnion fabed in need to finish welding everything and build drag link to connect Rack to inner tie rods!
  8. 71gold
    plan is... to install 1/4 window seals (thanks Rusty Auto Parts) and clean up front/back window trim (thanks Jeff) ...:yup:
  9. bradmosley
    bradmosley Member
    Pencsacola, FL
    73 Maverick
    ya all is good for the floats..set at 7/64....last night the carb was fine.... car finally started with no problem....vaccum reading is dead on....timing is at 10 btdc....still bogs when i accelerate. going to replace the vac mod tomorrow in hopes of not losing anymore tranny fluid
  10. kafrompa
    kafrompa Member
    Cedar Creek, Texas
    Are you runnin' a two stage carb? perhaps the secondaries are in need of adjustment, (opening too far too soon), just a thought...kafrompa "Garv"
  11. Joe Dirt
    drove it some,stopped and looked at a 76 2 door that was sitting at a local shop talked to its owner and refered him here,drove it home noticed it is still smoking from the header wrap soaked with trans fluid incedent and parked it.. too cold to ride in it with no heater..
  12. 71gold
    got the trim cleaned up...didn't leave any time for the 1/4 window seals after a 60 mile ride...w/T. S.
    ...:yup:...
  13. 71gold
    got the seals in today...:thumbs2:
    got a call from my painter today...he's ready for me to bring him the car...:yup:
    pics. later at the toy run Saturday...(y)
    ...Frank...
  14. 71gold
    went to install the trim clips for my window molding...cracked the front glass...called Hagerty, they said they will take care of it...:thumbs2:
    new glass...$174
    new window seal...$79
    install...$100
    having Hagerty Ins....priceless...:yup:
    ...P. D. W/T. S. ...:outtahere::chirp:
  15. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    New pitman from Rock Auto, rear brake shoes from NAPA and had the carb rebuilt. Filled it up with 91 and it runs like a "raped ape".:drive:
    :comet:
