  1. 71gold
    that happened to a Guy at the Gathering last year...his would hit when at idle and stop when reved up and the fan flattened out...:yup:
    looked like a nice day for the ride...:thumbs2:
    ...:Handshake...
  2. Tannersg1
    Tannersg1 Member
    Classified
    Rust is EVIL........
  3. Joe Dirt
    welded some more cable brackets up, found a new product to offer
  4. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    Just now I patched rear quarter panel and fender well, Pass side.
    My next plans are to...
    Gonna order & use 3m adhesive and stick cowl back on in the coming days.
    Then stick rearend back in and pull the old lady out, have front end aligned and start sanding the body down and get ready for paint :dancing:
    Still gotta order carpet, headliner, and oddball stuff and figure out what material/color to use on door panels and dashboard.
  5. sportyfamilycar
    KY
    (2) 77' Mavericks
    ..Oh and pray that I can manage to put all the dash/cluster, & interior back together the same way it came out :yup:
  6. mean_maverick
    just hollar if u need help :yup:
  7. sportyfamilycar
    KY
    (2) 77' Mavericks
    will do... i might have a ton of questions come assembly haha
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Pulled the Comet out,washed it, put it back in the garage.Got to love 47 degrees on the 5th of Febuary In Canada.
  9. Resto
    Resto Benders Evil Twin
    Yuma AZ
    welde and sand blasted then rust proofed.:oops:
  10. Joe Dirt
    Backed it out so i could do some welding..
    Debating dropping the rear suspension out
  11. mavgrab302
    Yesterday I replaced my damaged flex fan with a 5 blade factory part... With all the dents in it from the alternator bolt backing out I had a vibration... All is good now.... :thumbs2:
  12. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Soo, Left hand on Line Lock window squirter, right hand on shifter handle, waitign for light to go green, what hand os on the steering wheel? Even if your right hand is on the wheel, then release the lone lock when the light turns green, move left hand to wheel, then right hand to shifter to shift to second, I think is too much movement and hands on and off the wheel for a drag car. Imagine doing all this when the car gets loose off the line and you need to stay in the throttle to keep it straight.
  13. darren
    Agreed. Sounds like to much room for error to me.
  14. Nomake Wan
    Nomake Wan Member
    NorCal
    1974 Maverick 4-door
    Finished a round-trip between southern California and Northern California yesterday, have now put 1000 miles on her personally. Real great car, especailly for the cruise up and down the 5!:tiphat:
    For every ~400 miles she loses almost a quart of oil but the real problem seems to be on startup (especially warm). It doesn't blow clouds of blue smoke out the exhaust once started so I'm betting valve guides rather than piston rings. I'm thinking 302 swap rather than get the head redone though, seems like it'd cost too much for too little benefit to fix the 6. Too bad, too, it's in great shape otherwise!
  15. 71gold
    ...installed a 180 T-stat...:bouncy:
