  1. Tannersg1
    Tannersg1 Member
    Classified
    Sitting at work thinking i should leave early to work on it!!!!!!
  2. Ticktockmarc
    Ticktockmarc Member
    Rockford il.
    1976 ford maverick
    my maverick
    i pulled the trans out of the trunk and seen the sad trunk pans and realized that its going to be alot of work
  3. Resto
    Resto Benders Evil Twin
    Yuma AZ
    Yesterday after work I was sand blasting the engine bay till the sun went down. It was dark but I could still see enough to work. Every place the sand stream touched the metal glowed red orange due to friction heat.
    Now I know how shops are warping sheetmetal. I always keep the preasure below 80 psi just to make sure I dont make big holes.:)
  4. rayzorsharp
    Most people don't realize how much heat is created from blasting.
  5. Ticktockmarc
    Ticktockmarc Member
    Rockford il.
    1976 ford maverick
    threw the trash out and said hi to her
  6. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    took the 70 on a 2 block test run about 6pm:drive:top speed 45 mph!!!
  7. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Gave myself a deadline to get it on the road by setting a date for the Desert Mavericks dyno day. :thumbs2:
  8. Resto
    Yuma AZ
    More sand blasting after work.:drink:
  9. Red1972Grabber
    Northern California
    Replaced the battery terminals and then fired her up without needing the jumper cables. :thumbs2:
  10. maverick75
    Went to the Junkyard, it was a miracle. They had a TON of old cars. I'll make thread on it in a bit.
    Then when I got home I pulled the mock up 302 and C4. I had a 5.0/H.O. engine for it but sold it, so I'm still undecided on what I want to put in it.
    I've measure a SOHC 4.6L before and it does fit with the stock towers.... :D
    But of course another 5.0 is just plug and play...
  11. Dowtom
    Dowtom Member
    Baltimore, MD
    1977 Mercury Comet
    Today I decided to start tackling my roof and rust problems. I started cutting out the rust patches on the pillars cleaned up the rust behind it and hit it with a rust prohibiter. Tomorrow I will be getting sheet metal and my brothers mig to begin tacking it into place.
    What are some good suppliers of sheet metal? I can only take so much sheet metal from the local gas and electric company.
  12. mav1970
    I would look in your local phone books for steel fabricators or steel suppliers - there has to be some place within driving distance from you.
    I buy all of my steel from a local fabrication shop that also sells steel in sheets or lengths :thumbs2:
    I just bought 6 pieces of 14 guage steel sheared to 6" by 24" and an 8 foot length of 1/8 thick by 1 inch wide bar stock for 19 bucks from them :)
  13. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Changed thr distributor in the Maverick. Made a world of difference.
  14. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    :biglaugh:
  15. Dowtom
    Dowtom Member
    Baltimore, MD
    1977 Mercury Comet
    That wasn't exactly helpful, but I do laugh, knowing where i got it, if i didnt strip and primer some of the metal they would be orange and say men at work on it.
