  1. mav1970
    I like it a lot :bowdown:
    Maybe this June, when I come to York for that Expo, I might let you take me for a ride this time :yup:
  2. mojo
    Pulled a lot of stuff of the frt of the engine thinkin my water pump was shot. Come to discover the lwr rad hose was not exactly tight where it fits at the pump. I cud not see where the coolant was coming frm w/ all the PS pump and AC stuff in the way - I figured it might be coming frm the lower hole in the pump shaft housing. i did'nt feel any moisture there after removin the pulley or see any signs of a leak there. Im not sure it's not the pump, but Im guessing it was/is not the pump. I will know when I put it all bac together.
    It's not a wasted effort cuz I want to mount my elec fan w/ something other than the plastic stems goin thru the rad. To remove the fan I have to take the rad loose frm the support - don't like that.
    I had bought another wp - will probably just shelf it if the one on the car is not defective.
  3. Joe Dirt
    Cruisin' and doing some tune touch ups
  4. klynam
    klynam Member
    Big D
    1975 Maverick
    replaced the front disc brake retainer hardware - so far so good, no more rattling from the front end
  5. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Dropped the oil pan and fixed the stripped drain plug,reinstalled the pan.Spent some time cleaning up under the hood not 100% satisfied. May yank the engine to do a proper clean up.
    Did some work on the 68 Firebird.
  6. Joe Dirt
    spent the day working on the wastegate trying to get a little more flow through it.
  7. olerodder
    olerodder Member
    NorCal
    One last cold adjustment of the lifters (a little on the tight side to begin with) before I take it to the dyno on Thursday for test/tune next week...........................have 4 different sets of plugs from hot to cold for the motor, jets, gaskets, cams for the carb, need to install the fuel regulator, plug wires done, dist set w/springs bushings, filled with oil and primed, need to put on flex plate/adapter, have header gaskets and headers....need to take the coil out of the car to use, need to get header bolts..............need to get 10 gallons of fuel (112or114 is going to hurt the pocket book!).......................can't think of anything else.
    Hoping for the best..........................
  8. wgs226
    wgs226 Member
    westminster colo
    1977 maverick
    replaced master cylinder also replaced drivers door latch:shocked:
  9. grindfactor
    grindfactor Member
    South Carolina
    1972 Ford Maverick
    Just finished converting over to disc brakes for the front. Once I replace the tie rods and get some tires I'll be finally ready to roll! I've been sitting on this thing since February of last year!
  10. Joe Dirt
    Drove it to oreillys and it lifted a head blew antifreeze out everywere dumped k&w stop leak in and got home everythings dry now seems to run ok now too wierd..
    Damn tough little motor
  11. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Put gas in it and drove it to work today. First time taking it to work in a year. Going to try to do it once a week until it gets hot.
  12. Earl Branham
    Lugoff, SC
    Cleaning it up for the Stampede!
  13. gasjunkie
    gasjunkie Member
    uniontown, pa
    1972 maverick
    put a new front bench seat cover in from automotive interiors. it doesn't look and fit too bad.
  14. Joe Dirt
    Lifted the heads, all headbolts are loose got to pull the heads
  15. don graham
    I started my 70. Put the fenders and hoods on the Comet GT and the Sprint for pictures for Haggerty. Got both moved around and inside the garage. Will take pics tomorrow and also of the 71 Grabber in the trailer. :)
