  1. 71gold
    while waiting on an A/C bracket, I took a look at a starting situation I was having...I think I have it after 6 months messing with it.
    ...:drive:...
  2. Mav71
    Mav71 New Member
    1971 maverick
    Found out why my car was pulling to the left.. wasn't the tires... wasn't the tie rods or sway bar or anything fun like that... o_O Son of a *$&$#&@!!!!!!
    Turns out it was a issue with the steering column.. As its all bent to shiat
    yeah looking for a steering column now.. :mad:
    :rofl2:
  3. Joe Dirt
    Frank i have a couple of stock brackets if you wanted to use the gm compressor
  4. 71gold
    thanks...:Handshake
    but I'm ditching the "stock GM" for a Sanden...:thumbs2:
  5. Craig Selvey
    You will have to change the back seat as well. Your old 1971 back seat will not fit when you install the 1973 panels.
  6. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    Having the driveline lengthened. The engine swap moved the trany forward a inch or so.
  7. kafrompa
    kafrompa Member
    Cedar Creek, Texas
    1971 Comet, 2006 FiveHundred, 2007 Focus and 2008 Ranger XLT
    Mav71 If you need a steering column I've got one that needs the top end rebuilt including the key, lock cylinder and the cast collar they mount into. kafrompa
  8. mbcon212
    mbcon212 Member
    Mobile, Alabama
    1971 Maverick Coup
    Yea, I'm sure I'll have to change the bottom part of the seat but I'm hoping the backrest will still be the same. Thinking about completely re-doing the back seat area anyway and setting it up for my now-3-year-old daughter to ride in (she may be 4 or 5 before we actually get to ride it seems sometimes!). Just a single racing seat in the center of the back with a 4-point harness and also rig it so that a good child car seat will latch and tether in safely. Something where she can be comfortable and see the road but still be safe. I'm sure that will require some extensive mods to the seat or homeade brackets welded into the back seat area... She's so excited about our "new/old yellow Maverick" and want her to enjoy it too but has to be safe for her...
  9. mvrk70
    mvrk70 Member
    Indiana
    Flushed the tranny, new filter, new cooler lines, fixed the sloppy 40 yr. old linkage. Got the new timing chain and gears on and cleaned up the oil pump while I was at it since I had to remove the pan anyhow.
  10. Resto
    Resto Benders Evil Twin
    Yuma AZ
    What did you swap from and to? Which Trans do you have? Just curious.:)
  11. mojo
    Change the short rubber pieces of hose in my fuel lines. It appeared the one under the drivers door may have bn changed at some point, it had screw adjustable clamps and the rubber was not real brittle. The one at the tank had spring type clamps and the rubber was more brittle; it may have bn the original setup. i had changed the hose under the hood "to fuel pump" sometime ago, when I had the pwr steer pump out for overhaul.
    Anyway, I feel much better abt that springing a leak - most likely leaving me stranded. I had put it off much to long. Ready to make my first long ride of the season.
  12. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Good move!! :yup:
  13. mictn42
    mictn42 Member
    Goodlettsville, TN
    75 Maverick
    75 Maverick In Tennessee
    went through the drive shaft part all the way to the axles and I am happy to say all went well and I am back on the road with only a u-joint replacement. Was having a loud clunk noise and some drive shaft rotation when I put it into gear so I thought it may be time to rebuild the rear end but lucky for me the guy who owned the car before me had all new gears put into the car but was to cheap to replace the u-joints .....like a different car today!!
  14. Mysidekickgoose
    Mysidekickgoose Member
    Knoxville, TN
    1974 ford maverick 4-speed automatic I6, 94' Toyota Celica FWD I4 5-speed manual, 84' Toyota Celica RWD 2.4L I4 5-speed manual
    finished putting on 68 mustang cobra jet front discs on and today im finishing up the rest of the front suspension. should be on the road in a week or so. 027_1_original.jpg 026_1_original.jpg 023_1_original.jpg
  15. blugene
    Working on the headliner today. The dash is going in soon.
