  1. Tannersg1
    Tannersg1 Member
    Classified
    Installed new temp gauge....Nice to know what temp its running!
  2. Joe Dirt
    Thinking about riding to a cruise in tonight
  3. Xaan
    Xaan Newbie
    Germany
    70`3,3
    Exchange the spotlight to german standart.
  4. G3blues
    G3blues Member
    MI
    1972 maverick sprint 302
    Worked in the garage until it got too hot. Removed the steering column, rest of the dash support, brake lines and gas vent line. Hardest part was dealing with all the spider webs under the car. I really don't like spiders.
    Also took a closer look at my transmission and noticed that it wasn't original. The 302 block is but the transmission must have been replaced. It came out of a 73 something built in Kansas City if I am reading the partial VIN correctly. No more "numbers matching" for me:rofl2:.
  5. Joe Dirt
    Well i hosed it off and im sitting here at the cruise in nice little ride
  6. junrai
    junrai Member
    rancho cordova ca
    put the shocks back on and got the disc brakes all put on and hooked up. still need to do TONS more like getting bigger slotted and drilled rotors
  7. 71gold
    left mine out and and it got rained on, with the windows down...:cry:
  8. Del Austin
    Del Austin Member
    Chandler, AZ
    1970 Maverick & 1974 Maverick
    Finished the 2 bbl conversion! test drove the car, what a difference. Still a lot of work to be done, but this car being a driver limits how much work we can do at a time. Next step is to finish cleaning up the fender panels and firewall - paint them and start on adding ac, then power disc brakes.....
  9. Joe Dirt
    So in your opinion is it worth swapping to the 2 brl power wise?
  10. Del Austin
    Del Austin Member
    Chandler, AZ
    Certainly. Hard to tell just how much as the rebuilt stock carb needed some attention. The throttle response is greatly improved and the car runs so much smoother.
  11. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    Took it for a ride,left it parked. When I returned, SURPRISE!!! The brake pedal went down to the bottom. "Maybe it needs a liitle brake fluid"- I thought, so I refilled it. When I get in the car again, I pressed the pedal again... Down to the floor, i pressed a few more times thinking it needed to build some pressure, nothing. Then I hear a squirting on the driver's front wheel. I get out the car and checked the tire... All my brake fluid spilled on the floor. At first I thought that MAYBE the brake bleeder was probably loose causing the spill, but on a closer inspection it turned out that the brake hose was ripped up! Wrongly I didn't have my tools on the car so I asked the guy on a parking lot nearby for some tape. So I rolled it on the hose to try and reduce the leaking a little, I refilled the cylinder, and headed home which luckily was very close. It was a scary ride! :badwords::cry:
  12. nelson
    nelson Member
    va
    71 maverick grabber
    Caught mine on fire today
  13. bmcdaniel
    :eek3:Hope everyone's ok...
  14. 71gold
    another...E-brake...situation...:yup:
    it doesn't need any...brake fluid...(y)
  15. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Swapped the old Mallory distributor with a points type with Pertronix module. Now it starts better, sounds smoother and the initial hesitation is gone : )
