  1. rthomas771
    Went to a cruise-in and ran into my ex wife...longest 3 hours in my life
  2. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    Started stripping the parts car, swapped rear bumper and gas cap onto mine... looks 100 times better now, debating if I want to keep 73 bumper or go with the small on the front....
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Chase down a power steering leak
  4. 71gold
    they look pretty good tucked...:thumbs2:
  5. 71gold
    got a 2" fray in my new serpentine belt....going to see if I can find out why...:huh:
  6. 71gold
    found out why...one of the idler pulleys was cocked about .035 ...:bouncy:
    adjusted pulley and installed new belt...:tiphat:
  7. kiler be
    kiler be Member
    Culpeper, Va
    75 Maverick, 65Mustang 2+2, 03 Mach 1, 56 F-100, 99 Mazda 4x4 PU DD
    Started taking the 71 parts car apart.
    Its a shame, cause this car is very solid.
    Oh well......started a new spot in the barn.........MAVERICK PARTS ONLY! LOL
    Took the park bench off the front of the 75 and set the 71 bumper in place, WOW, What a diff. I think the front end raised 2 inches with the big bumped off. LOL
  8. Joe Dirt
    Picture sums it up i guess lol
  9. wjtkb
    wjtkb Member
    keystone heights fl
    maverick, 94 toyota pick-up, 94 honda accord
    I loaded up my ranger with my 2 doors, fenders, and front and rear valances to get them over to my dads work place so he can finish them up in his spare time.... its going to be an early morning for me so i can drop them off before i have to get to work
  10. mavgrab302
    Just Awesome...(y)
  11. Dave B
    Changed what I did last Sunday, almost where I need to be.....
  12. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    I just drove it some more. Car show yesterday. :tiphat::drive:
  13. Joe Dirt
    Yeah she rolled the window up and down probly 40 times lol
  14. Mavman72
    Finally painted the floor pan last weekend...
    Started stitching the towers this weekend...
  15. kboldin
    Santee, CA.
    Diagnosed my Fasten Seatbelt intermittent issue. Sometimes is lights up and sometimes it doesn’t. Also the chime has never worked.
    Found driver seat belt wire cut. Fixed it by soldering the wire back together and used heat shrink to seal it up. Found passenger seat belt warning sensor wires cut. Fixed them by unplugging the sensor, pulled the female connectors out of the coupler. Used small flathead to open the pinched wires on the female connectors, pulled out the cut wires and crimped the cut sensor wires back together, then I plugged the sensor back in.
    Tested the seatbelt warning system again, it failed. Reviewed wiring schematic for the 10th or 20th time LOL! Found blown fuse being connected by a gum wrapper (I'm actually guilty of this, I had to make a connection for electric fan on an MGB I owned at one time). Hey it works! You should always replace the blown fuse when you get home though!
    Tested the seatbelt warning system and it failed again… Found the backup lamp switch and noticed it had an oily substance on it. It's more than likely brake fluid coming from the brake master cylinder. It was already on my list of R&R items but now has jumped to the top of my list!
    It still doesn’t work but I did order the parts for the next jobs. All in all, it was still a great day! :)
