  1. 71gold
    never over.. just today I had to wash mine...:huh:
    see you in a little while terry...(y)
  2. Joe Dirt
    Fixing to go wash mine also
  3. darren
  4. RabidCustoms
    (finally) made and fitted the new rear firewall...
  5. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    drove on woodward... plan to head out again soon
  6. Moneymaker 1
    Panama City Florida
    Finished some things on the engine!
  7. rthomas771
    Drove it to Franks house (50 interstate miles) to meet up with Tim and Collin and to show Terry1 the rear disc brakes setup. While it was on the lift I notice one of the tie rods loose at the adjustment sleeve. We called Mike to see if he had a spare tie rod just incase the parts store didn't...he did, they didn't. Mike brought the part over to Frank's and we went to lunch. We replaced the tie rod when we got back to Frank's shop.
    A Large Time Was Had By All
  8. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    todays progress
    worked my 8 hours and got home about noon. changed the outer tierod end boots and the oil. took it out and put some one leged tattoo's around town.
    :jack::drive::burnout:
  9. Mavman72
    Lots of stripping paint and sanding. Forgot how small the eng comp was till, I spent too many hours in it today prepping it for paint...
  10. junrai
    junrai Member
    rancho cordova ca
    got the second door on got both fenders on bled the breaks adjusted the carb finished spraying the outside flat black. removed the interior wiring harness cleaned up the trunk floor and sprayed it. vacuumed out the 1/4 panels at the bottom. found some work to be done there later sprayed the back seat area flat black poked my powder coated comet emblem in the old seat to see how its going to look on the newly upholstered seats. (y) bolted the steering wheel down.wired the ignition switch up to start teh car with no harness.
    and did a fat burn out and broke my lower ball joint since I didnt have the car aligned yet after replacing the whole front end. :chirp: oh well thats what warranties are for anyway
  11. 71gold
    made 2 sets of rear disc. brake e-cables today. one set is for my car, I let Terry1 have the set off my car to finish out a rear disc brake swap kit he picked up from me Sat. .
    I will make another set tomorrow to finish out 2 rear disc brake swap kits ...1 installed, 1 to be installed later.
    that's 6 kits...so far...:thumbs2:
  12. maverickfever
    maverickfever maverickfever
    Winnsboro SC
    26 Mavs and Comets
    Water pump went and front main leaking bad.I may not make GA after all.Working 60 to 70 hrs a week and trying to keep up with everything else is all i can do.I hope i can get it repaired in time.I have been looking forward to the trip.
  13. kboldin
    Santee, CA.
    70k
    Worked on my reverse lamp switch and watched the clock kick over to 70k on the way home! :thumbs2:
  14. RabidCustoms
    I :deadhorse some more...........:D
  15. Moneymaker 1
    Panama City Florida
