  1. olerodder
    olerodder Member
    NorCal
    Those are maybe exactly the ones 7D2 Grabber has on his Comet................Looks really nice.....IMHO
  2. Paul Masson
    1971 Grabber
    Uuuuumm... it IS 7D2 Grabber:16suspect
    Here
  3. olerodder
    olerodder Member
    NorCal
    Well.....................guess I didn't read the top of the post.........thought it was ESampson....................guess I need some more coffee!:tiphat:
  4. 71gold
    had a new set of tires installed on the back of Patches...:chirp:
  5. Paul Masson
    1971 Grabber
    No wonder, all you do is... :chirp:What brand and size did you buy?
  6. 71gold
    the ones I took off are new...I just had them put on...:yup:
  7. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    Got front shocks/balljoints on the Maverick the other day. Running to autozone in the morning to get a new tie rod end ordered for the drivers side. might try my luck at getting the rear shocks off, was having issues and called it a day last time I was out there.
    Any tips for getting the rear shocks off? I have the top nut off, and the bottom is loose but the entire shock turns when trying to twist the nut off. tried holding the shock with a pipe wrench but was also exhausted and way past calling it a day at that point!
  8. 71gold
    doesn't the shaft have a...hex head...on the end of it to hold with a wrench?
  9. Craig Selvey
    Hold the body of the shock with a pipe wrench or a strap wrench.
  10. rthomas771
    I think it's a rectangle head. I use PB Blaster and vice-grips.
  11. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Can you get a impact gun in there?
  12. TrotMaverick
    Gaston, Oregon
    Never though about an impact gun, there should be enough room to get one on the bottom. I'll probably use the pipe wrench, that's what I was doing but i barely got it in there and decided to give it break and go home for a day. had an interview the next morning! going to get my tie rod end now, and maybe heater motor and fan. might make it out there between studying for a little bit and get those rear shocks off.
  13. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    impact works great for taking the lower nuts off the shocks. ive had to use a sawzall on some before.
  14. Del Austin
    Del Austin Member
    Chandler, AZ
    1970 Maverick & 1974 Maverick
    Towed it home after it was wrecked.
  15. bmcdaniel
    Say What? :cry:
