  1. Dave B
    I torqued the flywheel nuts, and put the starter back on...it was only 85 degrees in the garage. All that's left is bolt the slave cylinder back up, and put the exhaust back on...
  2. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Dura-blocks are basically the answer to finishing any body work for me! so straight with them.
    finally got the car started today! sounds so great..my issue was the seatbelt interlock..got that all figured out, still have fuel lines leaking so i have to fix that for the 4th time.. (stupid russel hardline connectorts, farrels just want to leak)
    besides that it's time to put it back together..still got all interior to put it, subframe connectors, nitrous kit, gears, and then the springs in the heads.
  3. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    hammer this way hammer that, end up back at the beginning, apply heat and quench to retighten metal, give up and apply bondo or glazing putty than sand it off and find out your not satisfied and begin again.... repeat for 4 or 5 time and totally give up for the day... repeat day after day... did I mention it was around 110 degrees for the last two days
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I put more stuff away that was sitting on the car. I can now see the hood and trunk!
    Both great albums but I don't blame you for passing on the other crap!
  5. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Switched car to full synthetic motor oil and ethanol free gas.
  6. Tannersg1
    Tannersg1 Member
    Classified
    No such thing up here!
  7. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
  8. mav1970
  9. Paul Masson
    1971 Grabber
    All we have to do here in Atlantic Canada is buy "Hi-test". No ethanol, except for 10% in low grade and up to 5% in mid-grade.
  10. predfan2001
    Sliced up the patch panels for the upper aprons. I still say this bench mounted metal hand shear is the best tool I've bought lately.
    Only took about 10 minutes.
  11. Moneymaker 1
    Panama City Florida
    Set up the geometry on the roller heads and set the valve lash, also painted a few things.
  12. 71gold
    at $0.30 a gal. more than regular w/ethanol...not for me.
  13. rthomas771
    But it has 5 more octane than regular w/ethanol or $0.10 more per gallon
  14. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Fixed fuel, oil, vacuum leaks, and adjusted the ignition timing.
  15. jdeeb
    jdeeb Member
    warner robins
    1974 Maverick Grabber
    put new windshield in! :clap:.......ps always make sure hood is properly latched before taking a friend out for a ride (y)
