  1. Joe Dirt
    ive got a stock one jeff
  2. rthomas771
    His is already modified for a Sanden compressor which is still attached. Came off a '69 Mustang. If he is giving me the runaround I will get back with you
  3. Craig Selvey
    I have a Sanden compressor on my 250-6 if you need any tips.
  4. rthomas771
    Craig- Might be a while on the A/C project. I wanna get the t5 swap done first. I'm going to use a t5 bellhousing with a early fork and try and make a 200 z-bar work.
  5. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    got off work...was 36 degree's inside my shop, after a while it cooled down to 32. managed to get a bit done, chevelle is DONE and ready to go..comet well..the rear end still not back together, hopefully tomorrow..then the head springs sometime before the weekend is over, got it all prepped to do them.
  6. injectedmav
    injectedmav Member
    Georgia
    Found out the hiem joints on the Baer tracker bumpsteer corrector are already worn out. It's only been a year and a half:mad:
  7. mavgrab302
    Ordered the hydraulics from rose hill performance... The t5 swap is getting closer :drive:
  8. Joe Dirt
    pulling the 250 tonight, five oh going in tommorow
    rubber by sunday if weather coporates
  9. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Thats scary. I havent noticed anything unusual with mine but have not REALLY looked either.
  10. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Going to be posting pics in build thread? Turbo'd too or just a 5.0 upgrade?
  11. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Picked up a used Weiand Stealth for the 302, and did some hammering and priming on the rear valance panel.
  12. rthomas771
    Removed a transmission from a '73 to get to the flywheel at the junkyard. One more part was added in the pile of parts for the t5 swap...one more part checked off the list.
  13. BigBlock
    BigBlock Member
    Illinois
    1970 Ford Maverick
    Removed front and back seats headliner and whatnot. Glad to finally get some progress done with my car. With the heat and all. I think next ill be removing all the rear drum cables and brackets. Then I got to figure out how the hell to get the hood off with destroying my grille.
  14. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I've seen some guys hang a block and tackle off a beam in their garage to pull the hood straight up, then roll the car out from under the hood and lower it down. Also seen a few people use their cherry picker to keep the front of the hood up like a second person, then just carefully maneuver it away from the car.
  15. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Replaced thermostat, installed electric ignition, set timing.
