  1. jsmithink
    jsmithink Member
    Colorado Springs
    1970 Maverick, 1960 2 door Comet, 1961 4 door Comet
    Went and pulled the 8" housing out of the junkyard today. Craziest thing happened...the backing plates fell off and somehow the backing plates and brackets from a Crown Vic appeared on it! :yippee: Looks like the kid will get the 5 lug and rear disc brake conversion at the same time!
    Also pulled the back bumper off the same car and put it on mine.
  2. rthomas771
    Get the CV E-Brake Cable to finish the swap. (y)
  3. predfan2001
    Ordered a lt rear marker light. Forgot I had used a rt frt bezel back there and it didn't fit very good.
  4. BigBlock
    BigBlock Member
    Illinois
    1970 Ford Maverick
    Hood finally removed took off that stupid latch assembly. Not too bad in the bay.
  5. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Started working on running lines for A/C
  6. mavgrab302
    My hydraulic clutch parts came in..
  7. jsmithink
    jsmithink Member
    Colorado Springs
    Last night I got the housing end clearanced for the Crown Vic brakes, which took all of 5 minutes to do!
  8. predfan2001
    Got those AK Sport mirror gaskets in. They do fit pretty nice. A little on the flimsy side though.
  9. injectedmav
    injectedmav Member
    Georgia
    Took apart the processor. It left me on the side of the road after 14 years without a single driveability problem. :mad: Found 3 burned capacitors. I may try and fix it.:smash:
    Anybody got any links for Ford EEC repair info?
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Struck a deal on an AOD for $50. Needs rebuilt but I would do that anyways.
  11. Joe Dirt
    finalizing some details
  12. jsmithink
    jsmithink Member
    Colorado Springs
    Got the 8" cleaned out real well...got the holes drilled out for the drain and fill plugs. Hopefully tomorrow I will have time to weld the bungs in.
  13. RMiller
    Kennewick, WA
    Found some parts on Craigslist that I'm going to buy if he still has them. A guy has some parts from a 72 Torino and my eye is on the console!
  14. rthomas771
    Got more parts needed to do a C4 to T5 swap. All I need now is transmission brace, fluid and maybe driveshaft cut down to size. Probably get started with the swap Monday.
  15. tody
    tody Member
    cologne, germany
    Please take a lot of pictures. I'm very interested in the shifter location of the t5 with the c4 hump.
    And as usual pictures of which parts of the brace you have to cut.
    I might take the same route. Which crossmember will you use?
