  1. C trout
    C trout Member
    South Carolina
    1977 ford maverick
    Finished fiberglassing the lower dash where the glove box and fuse box covers were, primed and painted.
  2. rthomas771
    I'm taking a bunch of pictures. (y)
    I plan to go with the 71gold style crossmember...if it fits. If it doesn't fit, we will be welding up a crossmember to use as a pattern for a new jig to make the t5 crossmembers. Frank has the AOD, C4, TKO, '70 t5 but needs the 71-77 T5 jig...or that's the way I understood our conversation when we talked about it. :huh:
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Picked up a few goodies I found on Craigslist. I grabbed a console and instrument panel from a 72 Torino, might use the console in the Mav and the gauges included a tach with all the other goodies...no idiot lights except the brake indicator. The guy also had a set of sport mirrors he thought were off a Maverick but it looks like they are Pinto. All the parts are in great shape and the investment was cheap enough.
  4. predfan2001
    I like that console. I used to be into 71-73 Mustangs and that looks similar.
  5. jv86
    jv86 Member
    Texas
    1972 Comet, 1962 Econoline P/U
    Today I bought a set of Sprint Sport mirrors (my 72 Comet only has the drivers side mirror) and a good condition dash pad. The pad and cap in mine is split in a few spots, and I think it might be fixable but I'd hate to try, fail and then start looking for a replacement. So I will try, and re-sell this one if my effort pays off.
  6. Joe Dirt
    drove it home
  7. speedfreak636
    speedfreak636 maverick student
    ga
    1971 Grabber and a 71 ironoxide experiment
    the begining
    We pulled it in to start its restoration. Started the tear down.
  8. Krazy Comet
    Pressure washed the pulleys and front engine accessory brackets, getting them ready for fresh paint...
  9. Moneymaker 1
    Panama City Florida
  10. junrai
    junrai Member
    rancho cordova ca
    ran it out of gas trying to put it in the garage and we did a compression check after resetting timing gear the compression got much better
    figured out after a leak down test its time for a rebuild on the bottom end
  11. Levi
    Levi CrAzY
    Tucson
    72 Maverick Graber, 2008 Mazdaspeed 3, 03 Chevy 4 door longbed 4x4
    finally the brakes are done!! Blead the brakes and put the rear wheels back on. Once the rains stop I can finish paintint the tranny lines and shocl tower gussets so I can put the car back donw on the ground and see how she sits with the 1 coil cut off the front springs. All I need to do is finish the wiring now and then she can fire up for the first time in almost 6 years!! :dancing:
  12. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    Ordered a new trunk mat, blasted the jack, and lug wrench, for the new paint.
  13. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I finally finished making a seat adapter that should hold my weight... the old ones started to tilt and twist the floor a bit... Also to hopefully give me a better seat position with my height.
    old;
    new;
    Now I'm thinking about removing the back seat so I can treat my plastic rear quarter panels which are dry rotting (Arizona heat)
  14. Krazy Comet
    Stole it's Motorcraft battery & put in in the 428CJ Fairlane Cobra...
  15. rthomas771
    Picked up a nice set of wheel well trim from the junkyard for $15. They are cleaning up very nicely.
