  1. mav1970
    I just checked my wire because I just changed the .023 out for heavier wire to do some frame work and I am using .030 for steel not .035 like I first thought :)
  2. olerodder
    olerodder Member
    NorCal
    I just went out and checked my tank and wire size. I'm down to 1200psi and the wire is .035. I've got some .024 on a new roll but I need to get some tips..............all I have are .035. Guess a trip to the welding store is in order this afternoon.
    Thanks
  3. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    John it's like night and day difference with the smaller gauge wire. I'd blow thru the old sheetmetal with my miller and .030 but with .023 it actually looks like a weld.
  4. Shorty
    Shorty Member
    Lafayette, In
    Reinstalled the 9" 4.10:1 geared Trac Loc center section, axles and wheels/tires in the Boss 302 housing in my Maverick. The wheels/tires are moved out just a bit from the factory 8" rear.
    Bruce:drive:
  5. speedfreak636
    speedfreak636 maverick student
    ga
    1971 Grabber and a 71 ironoxide experiment
    Started electrolysis on some parts today(rust soup)
  6. predfan2001
    Picked up a piece for hardboard to make a new rear package tray.
  7. Jamie Miles
    Alto, GA
    I've had a few
    Same old, same old.. Clutch started slipping last weekend if I get on it too hard while taking off from a light. Also noticed the car is leaving a bigger oil slick then usual after it's been parked for a few hours. Looked up under it and it's dripping out of the bell housing, rear main has started leaking... It's turning my collection of road grime under the car into a black gooey substance... :outtahere: Also notice my rear axle vent tube tore loose from the rearend. Guess that piece of hose finally gave up after 41 years and well over 400k. :rolleyes:
    Just going easy on it and hoping the clutch holds out for a bit longer..
  8. olerodder
    olerodder Member
    NorCal
    You are 100% correct. I had an old spool of .024 solid wire laying around and am using it............what a difference..........I can actually weld the thin sheet metal.
    Still have some cutting and re-shaping to do, but I'm sure I can make it work.
    Thanks!
      File size:
      818.6 KB
      38
      File size:
      684.1 KB
      39
  9. randytatum
    randytatum Member
    mccomb, ms
    About to put this.gasket on.... no more leaking on garage floor:D
  10. Levi
    Levi CrAzY
    Tucson
    72 Maverick Graber, 2008 Mazdaspeed 3, 03 Chevy 4 door longbed 4x4
    picked up the new hotter coil, some fuel fittings for the Holly carb, K & N top filter and a blower motor for the heater
  11. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Giving it the "Krylon touch"... taking more cans than I initially thought I would need...
  12. rickm
    rickm Member
    Owosso Mi
    Hey you welders I found something that drove me nuts. If you have .023 wire you have to to have the right size tip or your bead will jump from good to bad. I had .023 and a .030 tip and then I read an article that said the current flows from the tip to the wire and if your tip is too big you can get an arc there and it will show up in your weld.
  13. rthomas771
    Swapped out the C4 shift collar on the steering column to a floor shift collar.
  14. speedfreak636
    ga
    Making rust soup getting ready to put rear end back in
  15. 71gold
    ordered 3 new windshields today, be here tomorrow...:thumbs2:
