  1. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Finished the installation of the hydraulic clutch setup.. checked for leaks .. O.K. so far..letting it set until Monday to be sure .AC lines are next.
  2. doncomfort
    chillicothe oh
    Fixed an exhaust leak and got it ready for Pigeon Forge. 4 more days!!
  3. Moneymaker 1
    Panama City Florida
    Brought some outside color to the inside!
  4. 71gold
  5. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Took out all the power steering except the cotroll valve.. Going to need a puller for that and I can't find mine for some reason.. Then just got to wait for the manual steering to arrive from Marco, then ill head to the blaster and blast it all, powder coat and install it.. Other than that I haven't really done much.. Thinking of making a set of headers though if I get this engine back together before November.
    Oh, and got a set of m/t et streets.. Nice and narrow, all in the wheel well.. Didn't like the whole idea of getting Rock chips from the wide slicks.
  6. 71gold
    why do you need a puller, what are you pulling?
  7. Paul Masson
    1971 Grabber
    Bought some wheels and centers for "down the road" upgrades. :mischeif: :whistle:
    Sandblasted my exhaust manifold and started sandblasting my cowl pieces.
  8. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Fitted and put on the rear valance for a small bumper conversion.
  9. fomocomet
    fomocomet Member
    south ga
    comet
    Been thrashing on comet electrical system trying to make it roadworthy for the trip to pigeon forge.Found and fixed low voltage problem-power wire connecter on alt. was loose-soldered and now volts don't go below 12 with everything on.
  10. Craig Selvey
    Finally, after 7 years, had the leak fixed on my rear axle. Not a bad leak....just a drip, drip, drip all the time. Enough to leave a sizeable puddle. I didn't feel like messing with it, so I took it to the local shop. They have a hoist, know how to set the pre-load, etc. All the stuff ones needs to know to set-up a rear end. It was leaking out the threads around the pinion nut. So far, no drips. Now I feel safe driving it to the Indiana Mini-Meet this Saturday.
  11. Moneymaker 1
    Panama City Florida
    Tried once again to bleed the brakes, all four corners, r rear first and so on, when you pump the pedal, it has brakes, open bleeder and out comes clean fluid no bubbles at all, got done with all and when you hit the pedal, to the floor it goes, all new rubber lines, no leaks, pump it it has brakes release then hit the pedal, to the floor it goes! ordered new master cylinder (third one, not reman. new) will install Saturday after bench bleeding, last time before I shoot it with a tracer round! :thumbs2: :biglaugh:
    If I don't get brakes this time, my next step is to cut a hole in floorboard and do the Fred Flintstone thing.
  12. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I'm going through this same problem with my CJ 7 I'm on my third master cylinder, 2 remans one new. All new brakes all the way around and all new rubber and some metal lines, just ordered a proportioning valve because mine was corroded so that might be the problem, if you get yours fixed please let me know what you did I have been pulling my hair out trying to figure this problem out
  13. Earl Branham
    Lugoff, SC
    Had to get a new HP hose for my A/C in the Mav. Connector broke, let all the gas out. Nice to have the breeze box working again!
  14. Krazy Comet
    Mostly assembled the 306 that'll hopefully I'll get installed by the end of the month... Plan is to run it on a friend's test stand but he has it tied up at the moment with a 390 built for a '62 T-Bird... If the old FE proves out, should happen next weekend...
  15. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    If you changed calipers this MIGHT be your problem. A friend had the same problem. We bled and bled and still no brake pedal. In his case, he installed the calipers on the wrong sides. The only difference between the left and right calipers was the position of the bleeders. Calipers have to be mounted so the bleeders are at the TOP of the calipers.
    If that's not the issue, you might buy a pressure bleeder something like this. [ame="http://www.amazon.com/Motive-Products-Bleeder-Chrysler-vehicles/dp/B000TYJEXG/ref=sr_1_3?s=automotive&ie=UTF8&qid=1379079707&sr=1-3"]Motive Products Power Bleeder Fits late model Chrysler vehicles : Amazon.com : Automotive[/ame]
    You could look around for one that works with your master cyl or mod a spare cap to accept an air fitting.
