  1. jtown77
    jtown77 Member
    Arizona
    71 Comet
    I only have one uploaded so far
  2. jtown77
    jtown77 Member
    Arizona
    71 Comet
    Let me try this again... In the first pic you can see my new mustang floor pan too. lol I still have a little grinding to do
    passenger_cowl_top_before_original.jpg passenger_cowl_top_after_original.jpg
  3. 71gold
  4. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Yes I can take it I'm a big boy. Its mighty clean under there.
  5. mav1970
    Exactly the same repair that I had to do on both sides of my cowl - buying Mustang reproduction parts, I had less than a hundred into it when it was done :)
  6. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    He has his own lift....so he gets to spend a lot of time under there.:yup::thumbs2:
  7. jtown77
    jtown77 Member
    Arizona
    71 Comet
    welded in the driver's side mustang cowl.
  8. mav1970
    It looks like you still have a little surface corrosion to the left of your drivers side vent ring repair. I had the same and some were actually little pin holes. Instead of replacing that section, I used a putty knife with JD Weld and it made a nice rock hard coating. Then 2 coats of Rust Bullet over everything completely sealed it off. I used a flash light under my cowl and looked for any light shining through on the cowl top, it revealed those pin holes and anything else that I missed :)
  9. jtown77
    jtown77 Member
    Arizona
    71 Comet
    I cleaned it up some more after I took the picture. And I used the light trick. No holes on the drivers side, but found 3 more areas on the passenger side.
  10. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    Ok took some half way pics squeezing under that tight space on ground. I see a trans mount in my pic but not yours huh:hmmm:
    used up all my space for pics when I figure it out ill post pics
  11. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    Ok let me in on the confusion. WHAT TRANS ARE YOU RUNNING? I can see you have a gear/vendor hooked up. Where is the trans mount? Have you driven the car with the overdrive or is it just mocked up for now?
  12. 71gold
    it is a...C-4...
    I pulled the trans mount so the unit could drop down to service the fluid...this was at mock up.
    yes I have driven the car with the unit installed...:thumbs2:
    here it is bolted up...
      File size:
      102.4 KB
      36
  13. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    Thanks I feel better now. What gear do you run? Not that it matters or whether you care Im a Georgia boy born in Marietta been in Va since 79
  14. 71gold
    ...:thumbs2:...:Handshake
    3:55 gear.
    I found a pic, posted it in the other post.
  15. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    Nice crossmember, You make that? We run the same gear.
