  1. mavgrab302
    I may need one too, my stealth intake is a lot taller than my edelbrock... I like it...
  2. Dianne
    Dianne Member
    Nampa, ID
    1970 Ford Maverick, 1973 Grabber, 1973 Pinto Wagon, 1978 Mustang King Cobra II, 2004 Mustang Convertible
    We have weird weather in Idaho in the Treasure Valley here guys!
  3. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Been doing a lot over the last few days including, finished converting e-brake to "between the seats" instead of under dash, installed carpet, reinstalled seats, made leather e-brake boot and aluminum bezels for it and shifter, installed shifter and made a shift knob, and just got it fired up yesterday for the first time in 6 months... Tip, if your using a mechanical fuel pump preload the carb bowls, really helps.
  4. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Comet wouldn't stay on, took the carb off and put another one on since its been sitting. No go, rechecked the dizzy. Took it out and rechecked TDC, no go. Added a gal of gas just in case. Nope.... Figured out my MSD box took a dump. Weird part is I sent it in about a year ago to get rebuilt and its had maybe 10 min total run time. Also chipped a tooth on my new mini starter. Went back to the 5.0 style starter.
  5. x72COMETx
    x72COMETx Member
    Vallejo CA
    Made a divider between my back seat and started painting my trunk
  6. Dianne
    Dianne Member
    Nampa, ID
    Well Moneymaker, I started the air cleaner :) all primed in lacquer. Most work today was on the Mustang and a rear quarter on the Maverick.
    This is the start, another sanding and priming and then paint :D
  7. Angryeyes
    Angryeyes Member
    Canada
    Mercury comet, chrysler 300, Kawasaki ninja 600
    Then I went outside to the post man delivering a fuel cell, and two 6 point Sparco harnesses. Found a plate, bent up the sides and punched a few long bolts through it in the holley 2 bbl pattern, threaded nuts on to it so I can rest the carb about 4 inches above the plate. Then drilled a hole into the center so when the carb isnt up there I can rest the dizzy in it.
    Ordered more parts, took my dizzy apart, and started recurving it. Turning my reluctor arm into a 8L...
    Also grabbed a spare piece of paper and mapped out the ignition timing goals at various RPM/Loads to make sure it would work as planned
  8. Tannersg1
    Tannersg1 Member
    Classified
    What part number is that set-up?
  9. Red1972Grabber
    Northern California
    Got the new brake light switch in and also got the driver side bucket seat mounted.:dance: The seats are out of a 1990 Mustang and are pretty comfortable. Hopefully the passenger seat will get fab'd and mounted next weekend.
  10. Xaan
    Xaan Newbie
    Germany
    70`3,3
    change the sway bar bushings. Unfortunately still rattles...
  11. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    finish putting on the caltracs, got the rear sway bar back in since it started pulling thru the frame two years ago.
  12. 71gold
  13. jtown77
    jtown77 Member
    Arizona
    71 Comet
    My Son and I, stripped as many good parts as we could from the parts car. Not much left that isn't completely rusted away.
  14. Moneymaker 1
    Panama City Florida
    Waiting for the finished results, looking great so far! :thumbs2:
  15. Dianne
    Dianne Member
    Nampa, ID
    Thanks :) :bananaman
