  1. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Just a little :D
  2. mavgrab302
    I got a hold of a modern driveline t5 cross member for a 67/73 mustang. I've been curious for awhile now wanting to see if it would fit. Well I test fitted it and it looks like all thats needed is to trim the driver side tabs and drill two new holes, ditch the fox mustang mount and use a c4 mount and I should have a half inch of clearance between the shifter base and the floor.[​IMG] It will need spacers to because the mustang one is wider... I have Franks cross member to but if I can use this, I wont need to be under the car trying to weld his together... I'm not very good at welding to start with so under a car and with a part this important I'd rather try this first...lol
  3. bmcdaniel
    Be sure to check your pinion angle.
  4. mavgrab302
    I will check it,thanks... I was told to put a level on the intake and get it as close to level as I can, is this right or is there a certain degree I should set at the trans ?
  5. 71gold
    let the fun begin...
    http://www.carcraft.com/howto/91758/
  6. mavgrab302
    way to confuse me Frank...lol... If I understand it right, I should measure the pinion angle at the rear and set the trans opposite IE: if the rear is 3* down the trans should be 3* up... Sound right ?
  7. bmcdaniel
    That's the idea, you want the trans output shaft to be parallel with the pinion gear under power. I add a little more downward direction to the pinion as measured at rest, 3*, because the pinion gear will climb the ring gear when accelerating.
  8. jtown77
    jtown77 Member
    Arizona
    71 Comet
    Finished welding in the cowl. Now to grinding.
  9. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Spent a few hours scraping undercoating from my rear wheel tubs, and started prepping the inside floors for seam sealer and Rust Bullet.:smash::jack:
    Went by the upholstery shop for a talk with the Man about my Seat "Mods".
  10. Jamie Miles
    Alto, GA
    I've had a few
    Today I had a couple of used tires put on the ol' beater. That of course involved driving it... like I do every day. :D
  11. Mavman72
    Installed my new Chassis connection Export brace on the Sprint today. Fit perfectly, and looks good too...
  12. Tannersg1
    Tannersg1 Member
    Classified
    [​IMG][​IMG]Started it and let it run for awhile. Done some welding until I ran out of gas. Hung door on it to see how it fit. Not bad but I have new doors that I will hang tomorrow and mess with them.
  13. 71gold
    took Tims' Son J.T.for a ride today...:drive:...:chirp:...:yup:
  14. Moneymaker 1
    Panama City Florida
    Tried to stop the unstoppable, chronic valve cover leak, tried 3 diff. gaskets, some with sealer some without, stopping the leak is not happening.....:mad:
  15. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Liberated the hood skin from the bent, cracked and rusty frame. Next I need to clean the donor frame and skin then put them together.
