  1. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    Loaded it up into the trailer for the move to Spokane:drive:
  2. Red1972Grabber
    Northern California
    :drive: around for about an hour and a half. Stopping and taking a bunch of pics of my Grabber at some of the old local buildings, barns, gas stations etc. I'm in a very historical part of Northern California so there are cool old buildings and stuff everywhere.
  3. mavmet
    mavmet Member
    Auburn WA
    1972 grabber
    it is finaly alive
    drove the maverick for the first time in two years with the new motor it is very wicked just taped the throttle and put the tires up in smoke and went sideways.
  4. 71gold
    still...cleaning up a set of exhaust manifolds, getting them ready to be coated...:whew:
  5. Floydman
    Floydman Member
    Ma
    1968 Mustang, 1969 Camaro, 1970 Maverick
    Painted the dash, Installed a better looking dash pad, Put the right steering column in the 69.5.Next I tackle the ignition someone botched.And run through all the wiring so I can get some drive time in this year.
  6. Tannersg1
    Tannersg1 Member
    Classified
    Slapped some new doors on it and drove it around the block a few times!!!!:dancing:
  7. Craig Selvey
    Drove my 1976 4-door home from Dearborn, Michigan. About a 500 mile drive weekend.
  8. mavgrab302
    Clutch bleeding and more bleeding... I did get it working good enough to drive around the block once... Now back to more bleeding...
  9. Allen Small
    Allen Small Member
    Cannonsburg, PA
    73 Grabber/V8 and 72 V/8 grabber
    I finally got around to working on my 72 Grabber, could not decide if I was keeping it or selling it, but finally decided to keep it. I put a new heater core in and also installed a set of new tires and rims on it. Need to install a set of 1 1/2" lowering blocks to drop the rear some. Now just to get it inspected so I can drive it. Found out the wife accidently threw out the new registration card and plate sticker by accident, so I need to get a new one before they will inspect it here in PA. I still got a lot of cosmetic things I want to do to it here in the near future.
    Thanks
    Allen Small
  10. MoneyGRABBER
    MoneyGRABBER Member
    Philadelphia
    I took my 9" apart to check the gear ratio! 4:56 wow the mighty 351c was able to turn the rear with all 200 hp
  11. Tylermav94
    Tylermav94 Member
    Drumhellar Alberta
    1972 Ford Maverick
    Finished sanding up some of the body on the rear quarters. Now time to apply some quick time and get the body 100% also installing the 9 inch 32 spline today.
  12. z28th1s
    Lynchburg, VA
    Painted my sport mirrors for my '73 Comet and bought a factory GT hood scoop.
  13. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    got my new auto meter gauges installed, and wired up to the headlight switch. The cluster on the tunnel is made from a pinto console
  14. MoneyGRABBER
    MoneyGRABBER Member
    Philadelphia
    Mocked up 275/60/15 drag radials with an 8 " rim! If I was a regular dude it might fly! Calverts and a mini tube is only right! It's only money I'm losing in hopes to gain more
  15. Earl Branham
    Lugoff, SC
    Had the windshield resealed. Now for a rainy day to see if it is tight and dry inside!
