  1. jtown77
    jtown77 Member
    Arizona
    71 Comet
    Got the headliner installed.
  2. Drew Hierwarter
    Drew Hierwarter Member
    Kingsport, TN
    1976 Comet
    Took the Comet to it's first local car show today.
    Nice small show at a local church. Lots of fun.
    Paul Masson likes this.
  3. Paul Masson
    1971 Grabber
    Installed upper and lower control arms, along with roller spring perches and the voltage regulator. I had the kids helping me, so I was going for simple installs with some eye-candy for them. Back to blasting brackets and small parts...
    doncomfort likes this.
  4. Mavman72
    Pickled the Sprint for the winter...Just waiting for spring/summer now.
  5. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Went to the good guys swap meet and found a bumper shop that had a set of rechromed comet bumpers. Had to give mine up as cores but I think I came out ahead. $460 for a front and rear for a set of 71 rechromed comet bumpers with bolts.
    mavgrab302 likes this.
  6. mavgrab302
    Fixed a short in my steering column, turned out to be a missing spacer in the Grant adapter that caused the wheel to sit to close to the turn switch... No more sparks... Also had a ticking in my engine that turned out to be loose header bolts, fixed and no more ticking... The car is running very good now...
  7. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    put in a disconnect switch for onboard charger. learned not to leave a onboard charger hooked to a battery when not plugged in. weirds out the cars charging system and drains the battery over non running time. drained a new battery to 0 volts, lucky it took a charge.
  8. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    walked by it and stole the battery for my other project.
  9. stroker mav
    stroker mav Member
    canton, ohio
    1964 country sedan,1933 essex terraplane
    [​IMG]mock up for 347 ,we will call this part 1 because I still am not sure of what Iam doing on this forum. 003.JPG
    wicked mav, Paul Allen and Tannersg1 like this.
  10. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Since the snow is here and 16 degree weather I did not work on my old girl outside. She is covered.
    I stayed in the heated shop and sanded Centerline aluminum wheels. Man is that a chore to start with heavy grit and work your self up to 2000 grit then polish. I am at 1500 grit now. My first one is almost done , looking really good and will take a pic then.
  11. mavgrab302
    Took a road trip up to Hilliard,Fl. Picked up a set of power disc brakes for my sprint... I was treated to lunch at the Shack at the track, a cool old BBQ joint that is right on the R/R tracks... It's in Saint George, Ga. Good Times :thumbs2:
  12. 71gold
    took mine on a 50 mile cruise....:drive:...:chirp:
  13. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    I now have brakes! All weekend to get them bled right. I had all new components and decided to go with DOT 5 silicone fluid. Not for performance, but because it doesn't eat paint. Maybe one of the best bad decisions I have ever made. I had the fluid all over the place, so I think it paid off. Also, working with stainless lines is a little more challenging than soft steel. Lot's of leaks. Yes brakes appear to be a little spongy, but it'l stop fine.
  14. stroker mav
    stroker mav Member
    canton, ohio
    Paul Allen likes this.
  15. Krazy Comet
    Dismal Swamp
    I've had silicone fluid in my Cobra Jet since 1992, never noticed any sponginess(yes I know DOT5 is supposed to compress slightly)...
    I've found the rears on my Comet will gravity bleed, fill reservoir, open valve at wheel cylinder(one only)and just let it drip... If there is any air they'll be periods the drip stops, when sure doesn't have any more air, close bleeder and open opposite side... Whole process shouldn't take more than 15-20 minutes... I vacuum bleed my fronts but am fairly sure they'll gravity bleed as well... That's when the lines are mostly full of fluid, isn't going to happen with dry lines..
