  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    Thanks. I'm thinking I'll try some more bleeding/dripping later and maybe eliminate the spongy feel. I probably have alot out of adjustment, just happy to have all pads hit before brake pedal bottoms out! I need to get it moving now. (and....I'm sure I can turn that 15-20 minutes into a day)
  2. mercgt73
    mercgt73 Member
    Took some measurements in order to buy steel for making brackets to mount the shell on the rotisserie...
  3. jtown77
    jtown77 Member
    Arizona
    71 Comet
    Got the quarter window seals and windows installed.
  4. Krazy Comet
    Finally, after over a year I got the shock tower braces fully sand blasted... For some reason there was a bunch of undercoating on them that needed cleaned before I could continue blasting them... Also yesterday before it got cold, I connected the electric choke and glued the button to windshield to hold rear view mirror...
    You guys know the Sport Mirrors suck for visibility, right??
  5. 71gold
    depends on where you mount them...:yup:
  6. Paul Allen
    Paul Allen The Maverick is back!
    Middleburg Florida
    1972 Ford Maverick
    Got some new tires and wheels for the front on my car. They were given to me by a friend. Weld racing 15x4 aluminum wheels. Got a set of four wheels, but the 15 x10 rears had the wrong backspacing. Damm all of the bad luck, well at least I only have to purchase two wheels instead of four.....
  7. Krazy Comet
    So I'm supposed to move them from factory location??
  8. 71gold
    yes...there is a writeup on here somewhere.
  9. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Do you know the link about the sports mirror mounting Frank? can not find it.
  10. Mel Moeller
    Twin Falls Idaho
    Never mind Frank. I found it.
    From the center of the rear hole to the back edge of the door is 32 and 3/4".
  11. 71gold
  12. Howard Forbes
    Howard Forbes Member
    Chesapeake, Va
    1972 Maverick , 1977 Cobra II
    Finished moving the shock towers and got holes drilled for AJE front end.
  13. 71gold
    how far did you move them?
  14. Howard Forbes
    Chesapeake, Va
    Moved them 2 1/2 inches each side. Had to raise them also for things to fit together. Still have alot of finish work to do.
  15. Howard Forbes
    Chesapeake, Va
    I'll eventaully do a build thread when I get further along. Did do a test fit tonight and it looks like plenty of room.
    Krazy Comet likes this.
