  1. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Use the heat gun.
  2. dtb147
    dtb147 Member
    Arbutus, MD
    On Monday I rebuilt the Autolite 2100D on my 302. Yesterday I diagnosed a misfire. Today, with the advice of other board members I was able to track down a vacuum leak and now the car is running better than when I bought it! :cheers2:
  3. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    A little more progress today. All that's left is the roof, tail panel and both valences.
  4. 71gold
    what did you strip it with?
  5. jtown77
    jtown77 Member
    Arizona
    71 Comet
    Do I start at the edges of the wrinkle and work in, or the center out. This was my first headliner.
  6. Earl Branham
    Lugoff, SC
    Put a new drive shaft in my car today.....3/4" longer than the stock one. Car runs a lot better at upper speeds, but still has a little vibration. However, I think a good balance on the rear tires might be in order. I'm happy with the driveshaft, so now to do some cleanup and some long needed maintenance.
  7. Mel Moeller
    Twin Falls Idaho
    I would ask someone to help you. It is very easy to ruin a headliner with a heat gun if you have not done it before.
  8. 71gold
    too hot will leave shiny spots, it takes the texture out of the material.
  9. Mel Moeller
    Twin Falls Idaho
    It also can melt right through, let the glue give away and let the seams separate. I saw this more than once and repaired these problems when I had my Upholstery shop years ago.
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I was lucky with the headliner I put in my GTO, no wrinkles! It was my first and only headliner, such a pain that I will gladly pay someone to install it in the Mav.
  11. jtown77
    jtown77 Member
    Arizona
    71 Comet
    I guess I'll use low heat and a very slow application of it. I thought the sail areas were going to be the real problem. They came out pretty good. I think the new quarter window seals were harder than the headliner. Those were a real pain.
    Picked up the new windshield this week. Hopefully putting it in sometime this week.
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Cut the old pins out of two worn door hinges in preparation for another trip to Marvin the sandblaster.
    doncomfort likes this.
  13. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    Finally got the Transmission in. Maybe this will run before spring!
  14. 7D2 Grabber
    7D2 Grabber Member
    I used a hair dryer instead of a heat gun when I installed mine. I started from the middle rear and worked my way forward. I went to Office Depot and bought a bunch of the metal clips to hold the headliner in place. I'd pull the headliner and set it with the clips then would come back to it if it needed to be pulled some more.
    For glue I used a product from DAP in a red can, weldwood the original. I let this sit for a couple days and kept the headliner in place with the black clips in combination with wind lace. Good luck
  15. Tannersg1
    Tannersg1 Member
    Classified
    That looks real nice!!!!
