  1. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I wonder why Ford decided to spend the $$ on SS for 75% of the brightwork trim and go with cheaply anodized aluminum on the rest? The anodizing has a "pitted" look about it and must be stripped to get the aluminum trim to buff up properly.
  2. Craig Selvey
    Probably easier to make items out of aluminum due to size and softness of the material.
  3. Shorty
    Shorty Member
    Lafayette, In
    Ordered new 3-point retractable seat belts from Juliano's to go along with the new Fat Mat and carpet that I have for it. Going to heat up the garage and get after it this next week.
    Bruce
  4. 71gold
    road over to my upholstery guy to get a price on making a set of door panels...:drive:...:chirp:
  5. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    I bent new Transmission lines yesterday. I only had the nut on the wrong side of the bend 2 times. A longer day than necessary again! Next time, I'll tape the nuts to the ends before starting any bends.
  6. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    yepee, got my comet started, took it around the block a few times. Got it tuned where it doesn't stall when trying to take off from idle. had to back of the fuel accel setting on the ezefi a ton. might need bigger injectors, its running at about 50% injector at idle. ran through all the gears fine, down shifts fine.
  7. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    While driving today down the I25 my coil quit, wife brought me an old coil I had laying around but no tools. Strapped the good coil on with a iPod arm band and drove her home.
    Krazy Comet and Shorty like this.
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Sub-frame connector #2 is in, now to cut and fit the floor pans.
  9. Rasit
    Rasit Member
    SE Pennsylvania
    Got it up on blocks and started on the tranny removal for a winter rebuild....
  10. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Looks like you have room to put in a two post or 4 post lift. Good looking car!
  11. RMiller
    Kennewick, WA
    That is a nice garage!
  12. Rasit
    Rasit Member
    SE Pennsylvania
    Thanks! Built the garage, bought the car and am concentrating on getting it running like I want ($$$!) . The older I get, the more I want a lift.....
  13. mav1970
    Getting a bit of help from Mr. Yuengling, I see :thumbs2:
  14. stroker mav
    stroker mav Member
    canton, ohio
    1964 country sedan,1933 essex terraplane
    Pics of 418w headers with 2'' primaries and 3 1/2 collecters with stock maverick suspension.Engine was moved back 1'' to make room between drag link and bellhousing for 2 tubes. You can put 10 lbs of crap in a 5 lb bag if you try hard enough .
    Paul Allen and Moneymaker 1 like this.
  15. Mel Moeller
    Twin Falls Idaho
    That's a clean job and a clean shop.
