  1. mav1970
    Wow!! that is quite a tight fit :yikes:
    All custom made I presume - nothing looks off the shelf
  2. Moneymaker 1
    Panama City Florida
    Looks great....where's mine? :rofl2:
  3. stroker mav
    stroker mav Member
    canton, ohio
    1964 country sedan,1933 essex terraplane
    A friend of mine did all the cutting and tig welding , he is very good at what he does. At times we had some of the tubes in and out 6to8 times to cut and refit before tacking.These headers are 10 piece with slip on collecters and are user friendly, all header bolts go off and on with 1/4'' ratchet and 3/8'' socket. As do plugs and wires.
    JoeB likes this.
  4. Moneymaker 1
    Panama City Florida
    Got the timing chain and gears on, tried to check piston to valve clearance and the damn Play Dough only wanted to slide down the face of that forged piston, going to try again another time.
  5. junrai
    junrai Member
    rancho cordova ca
    super nice paint job above love that color
    I swapped the filler neck and put in a rubber ring in the gas tank hole then put the screw down piece in the floor of the trunk YES no more gas smell and put on a perfect back bumper
    Moneymaker 1 likes this.
  6. Moneymaker 1
    Panama City Florida
    Got the piston to valve clearance check done, it was fine, bolted on the heads, got the pushrods in and roller rockers on, set valve lash, bolted on timing chain cover with water pump and prepared the oil pan for installation later.
  7. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    Installed a new fuel tank. Yes, I'm getting desperate to run this thing. Maybe by the weekend!
    biggruss and Paul Masson like this.
  8. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    You ought to be proud of your car. Nice things don't come easy. I would be anxious too!
  9. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Went to Eddie's Body Shop to drop off my subframe connectors, rebuilt door hinges and front fender/door bolts. Looks like it will go under the gun in a few weeks
    Craig Selvey likes this.
  10. scs
    scs Member
    Prescott wisconsin
    Thanks! I am very happy today. It finally ran after 33 years of rotting. I have had a lot of bad luck on engine rebuild startups, but this one went fine (except it was below zero outside). Maybe the MCCI rally in Washington PA is in reach!
  11. Craig Selvey
    You have to be a dedicated gear head to go out and start a car when it is below zero. :D
    Paul Masson likes this.
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    You'll make it to Washington. It's me I'm worried about:(
  13. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    Finally got Mia a spare :whew:
  14. scrapper60
    scrapper60 MCCI Member
    Alabama
    drove it.
  15. Red1972Grabber
    Northern California
    Ran out of gas for the second time in four days. For some reason it's only getting 6 miles per gallon instead of my normal 8 miles per gallon.:huh:
