  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Also ordered my leafs from laurel mountain mustang, heavy duty 4 leaf for 169, hard to beat that price.
  2. Moneymaker 1
    Panama City Florida
    Started it up! not for long, got a few more things to hook up but I just wanted to hear it bust off, and DID! :yahoo:
  3. Krazy Comet
    Well I fixed the leak again...
    Above repair helped as it's not leaked as badly, but I found the metering block was leaking from the plug that was inserted after accelerator pump passage was drilled... Drove a small punch into the plug(more like a aluminum BB), and that apparently stopped it...
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    But will she help install the C4 thats sitting on the floor?
  5. Krazy Comet
    I reset my shade tree front end alignment...
    I wasn't sure it would be "alignable" so I measured Brian's Maverick that had just came from alignment shop and found it's wheels were approx ½" forward of mine, so cranked on the strut rod adjustments till they roughly matched... Dayum what a difference!!! Is much more stable and eliminated most of the bump steer, now doesn't try to change lanes when I back off from a WOT punch at 50-60 MPH...
    Once warm weather finally arrives, I'll take it to the shop for a proper alignment...
  6. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    ordered a new efi fuel pump. damn I wish this Chinese crap would last at least a month
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    UPS guy dropped off my aluminum driveshaft.
  8. 71gold
    hope it wasn't damaged...:bouncy:
  9. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Perfect shape!
  10. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    Installed my modified throttle cable bracket and welded lugs to the steering column to installed it.
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Got a bunch of Misc stuff from Melvin's.
    Went to Eddie's to see the car. The early rear valence does not line up very well with the 74 quarters (valence seems too narrow). Working on getting a better fit with a touch of filler.
  12. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    I've been watching some leaks hoping they would go away. I'm thinking this is a bad Maverick day. Oil continues to drip from the tranny bell following a 10 minute run a month ago (that should stop since the oil level should be below the seal, right?), some oil still dripping from under the front harmonic balancer and coolant continues dripping from the radiator. This is a brand new rebuilt engine and new aluminum radiator! I was hoping I could finally have a car that I could park without leaving my mark.
  13. Moneymaker 1
    Panama City Florida
    Don't feel too bad, I have a coolant leak somewhere either behind the water pump or timing chain, new stroker engine with 10 minutes run time.
  14. 71gold
    I pulled the low level oil sensor out of the oil pan and threaded it for a 1/2" pipe plug. it has seeped since day one. then I found out I could have bought a metric plug to have replaced the sensor...:slap:
  15. Paul Allen
    Paul Allen The Maverick is back!
    Middleburg Florida
    1972 Ford Maverick
    20150204_201913.jpg 20150204_201926.jpg 20150204_202000.jpg Went to Georgia and picked up my new race transmission and converter. New 8 inch unit and JW Performance Ultrabell. Complete with deep pan and transbrake. A pretty trick piece if I do say so myself
    Paul Masson likes this.
