  1. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    2 door 73 Maverick with a 302
    DSC00914.JPG Had fun removing old front suspension, new one on the way.
  2. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Looks nice. What kit did you go with?
  3. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    Nothing to fancy just a laural mountain kit with a 1 inch drop. thinking about updating the spring perch, I would hate to have a squeaking front end after all the work.
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    installed my new power steering pump and lines and boy im glad to have power steering again
  5. mavgrab302
    Pulled the trim from front and back glass.. removed the rear bumper.. time to pull the engine and trans so I can replace the battery apron and core support... The Sprint repair is underway...
  6. 71gold
    called my powdercoating Guy around 12:30 today. he told me to bring the parts in. got them to him around 1:30...picked them up at 4:30...:thumbs2:
      File size:
      86.7 KB
      File size:
      34.5 KB
      File size:
      36.1 KB
      46
      File size:
      87.9 KB
    Paul Masson likes this.
  7. 71gold
    parts were a little too shinny for the look I wanted. took them back today and got the color adjusted...:thumbs2:
    now on to the cleaning of the car before install tomorrow...:yup:
  8. Krazy Comet
    Was almost 70* today!!!
    Repl the incorrect passenger side strut rod bushing spacers, cranked on the caster a bit more and went for a quick ride(hard to find a dry road with all the snow melt we're seeing)... Finally drives decent, has equal suspension compliance on R & L, aggravating bump steer is gone...
  9. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    So far, I've spent probably 50 hours on a custom wiring job. But, it finally started and ran as expected today. I could have saved 10-15 hours by pumping the gas pedal first before trying to start it. I assume the frequent stalls were a wiring issue, ughhh. Probably 25-50 hours more needed for the auxiliaries. Lots of rework, but it's all coming together. A good day!
    Paul Masson, mavgrab302, JoeB and 2 others like this.
  10. mstolarc
    mstolarc Member
    Livonia, MI
    1971 Comet GT (clone)
    Started to work on the engine rebuild. New Comp Cam, Trick Flow aluminum heads, roller rockers and Weiand Stealth intake manifold. My brother also rewelded/reinforced the rear shock brackets that mount to the frame, since both of mine have broke loose over the past year.
    Paul Masson and mavgrab302 like this.
  11. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    replaced the a/c compressor, I have a guy in Memphis here making up custom ac lines ;). will be ready for the southern heat.
  12. 71gold
    got everything powdercoated/painted/installed except the rotors and calipers on my frontend...:bouncy:
  13. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Godmans hi performance can make the A/C lines for you. They are off of Covington Pike.
  14. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Nothing unfortunately, been like that for quite some time. Gotta get remotivated
  15. 71gold
    did you take him the car or is he just making lines that are not stock?
    I got all the fittings and installed them. then cut the hoses, marked the orientation to fit so the writing would not show. then took them back to the A/C parts supply store and they crimped them...:thumbs2:
