  1. Ryan Whiteside
    Ryan Whiteside MCCI SC State Rep
    Upstate, South Carolina
    1969.5 Ford Maverick 302
    Rewired everything under the hood. Starting on the under dash wires tomorrow. Going to be a headache. Looks like a birds nest under there
  2. 71gold
    got everything wired up just need to tuck a few wires and test drive...:drive:...:chirp:
    just got back from an 85 mile test run...sweet
    97 degrees out...85 MPH...2300 RPM...204 temp...A/C chilling...:thumbs2:
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Started my re-rebuilt engine. In the process of computer tuning.
    Micah
    Paul Masson likes this.
  4. rthomas771
    I added 1" lowering blocks that Earl gave me years ago and I used the new U-bolts that Frank gave me months ago. The blocks put the rear back down where it was before I bought new taller tires...went from 235-60's to 245-60's. The tires fill the wheel opening a lot better with the lowering blocks.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Replaced the accelerator pump on the carb, fixed front right broken self adjuster for the brakes, got a state inspection, and insurance.
  6. Paul Allen
    Paul Allen The Maverick is back!
    Middleburg Florida
    1972 Ford Maverick
    Went through the car and checked every nut and bolt I could get to under the car to make sure nothing came loose after my first weekend at the drag strip. Everything is tight and car is working like a champ! Gonna step it up this weekend and see what kind of numbers I can produce..
  7. rthomas771
    I was going to clean up the Maverick to get ready to go to a car show and notice the fan belt slipping. After tighten the adjustment bolt I saw the alternator move and the belt was still loose. I thought the adjustment arm weld broke loose from the alt/AC mount. The reason for me to think this is because the aftermarket bracket that I had in my hand a few days ago has the adjustment arm welded on. I didn't think to think cast iron at this time. I started removing stuff to get to the AC bracket to try and weld things back together. After I got the radiator out of the way I could see the problem. Talk about being lucky...it sure saved me hours of working in this hot weather. I made it to the show on time with a dirty/non-squeaking car
  8. Northern
    Northern Member
    '74 Maverick
    Swapped the icm again. New ignition switch. New headlight switch. Removed electric choke. 1st crank in about 2 months.
    10 mile test run was great...maybe i fixed it.
  9. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Assembled the sequential taillights for the '70 Maverick .. Really makes a difference .. not too worried about someone tailgating me anymore .. if you don't see THESE you gotta' be blind .
    Cometized
    (Chip)
  10. yellow75
    Tillamook Oregon
    Took the steering wheel off to recover it with one of the covers that mercgt73 makes for the sport steering wheel with finger grips
    mercgt73 and tody like this.
  11. rthomas771
    I finally got around replacing the clear door glass in the doors with factory tinted glass. Driver’s side went smooth...took maybe 15-20 minutes to complete start to finish. Passenger’s side was another story...took about an hour and a half. Had to cut the rivets out with a Dremel and small cut-off wheel and everything else that could go wrong went wrong. My left hand and wrist looks like I got in a fight with a cat. I now have a complete set of tinted glass on my Maverick
    tody likes this.
  12. Howard Forbes
    Howard Forbes Member
    Chesapeake, Va
    1972 Maverick , 1977 Cobra II
    Mocked up the engine. Getting ready to install it again to send out for roll bar , intercooler and radiator mount fabrication.
  13. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Finished the wiring in the Maverick for the Power Window Conversions .. I opted for the "traditional" look and kept the original window cranks . The last four cars we've finished has this type setup . Push the handle UP 1 inch for raising the windows ..Push the handle DOWN 1" inch for lowering the windows . Also added color-coded insert in the stock handle and chrome turn knob. Lotsa fun at car shows when demonstrating. I'am doing a " step by step" article on my website for these if anyone is interested . Requires some fabrication and drilling.
  14. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I like the idea of that but my fear would be someone cranking on them thinking they're manual. Will they hold up to that kind of pressure?
  15. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Not to wo
    Not to worry .. Anyone I let ride in my car is advised immediately to NOT try to crank them. Anyway I live in Florida and my AC is always ON so there's no need to try the handle. The handle will only go down or up as far as the switch inside the door will allow it to which is about an inch and no more , it won't turn a complete revolution .
    Cometized
    (Chip)
