  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Converted the steering column over to a floor shift using 71 - 73 Mustang column collars.
  2. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    wiring, and more wiring. mounted my megajolt in the dash. I ordered my edis-8 module and two coils. need to order my sparkplug wires. trying to figure out what model, brand, I want to purchase. or just re tip the old ones I have (dui livewires)
  3. 71gold
      File size:
      120.2 KB
      24
  4. 71gold
    got the car on the lift and the tools ready.
    Jeff is coming tomorrow morning and we will install my new gauges...:thumbs2:
  5. 71gold
    post should have read..."Jeff is coming tomorrow morning and we will uninstall my gauges"...:thumbs2:
    now that the cluster is out I might as well paint the dash...:yup:
    also there's a plan B on the cluster bezel, I desided to keep the one that's in the car. it has the trip/reset switches and shift light already installed in it so I won't have to drill holes in the one I just restored, I just need to repaint this one...:bouncy:
  6. bomrat
    bomrat Member
    major push on wiring yesterday. spend about 5 hours. about 90% wired. waiting for edis coils and edis-8 module
  7. 71gold
    got the newer cluster bezel cleaned and painted...will get it taped off tomorrow for final paint...:bouncy:
  8. bomrat
    bomrat Member
    ordered new plug ends, starter switch ( getting flaky ). finished up wiring under hood. cleaned up shop some.
  9. 71gold
    got the final paint on the cluster, just need to peel off the tape, assy. it and install...:bouncy:
      File size:
      77.1 KB
  10. x72COMETx
    x72COMETx Member
    Vallejo CA
    That looks really good
  11. dyent
    dyent Member
    vancouver bc
    finally starting to put back together my 73 Comet, testing fitting of modified export brace, removal of original front coils springs, side by side comparsion between it and 70 Boss 302 Mustang cut down 620 lbs spring. All these where off my 74 Comet, so everything should fit.......
    another side by side comparison between Koni's and KYB excel G, Koni's where the only shocks that could
    control those 620 coils, with its 5 adjustments.
    Sleeve made for coil spring compressor, so threaded rod does not bottom out on spring perch.
    Great thing with those cut down 620's, do not need compressor to reinstall!
    Customized Champion CC339 radiator, had Ledfoot Racing install plate on passenger side to cover opening
    from the OEM factory A/C. On my 74 w/o A/C, did not have this cut out on the rad support, also had to
    move the lower outlet to the passenger side to match up with my water pump and to make sure everything
    would clear the front crossmember........
    touched up the firewall reinforcement plate, where the pedal support/master cylinder bolts up, brake fluid ate away some of the paint, close match using plastic model paint enamel! Will try and see if carpaintonline has an OEM paint code match (thx. 71 Mavrk!).
    Hopefully will get all the "rollerized" control arms in before weather turns ugly........
    David
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I have the same spring compressor and found it was too long for any application I used it for so I cut down the rod. Works like a champ now!
  13. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Put some color on it.
  14. RMiller
    Kennewick, WA
    Color is so rewarding, can't wait for the day!
  15. 71gold
    got the Dakota Digitals installed...:drive:...:chirp:
