  1. ra3psd
    ra3psd Member
    texas
    72 maverick grabber
    One other tip about the Cragars, keep the washer flat against the wheel while tightening the lug nuts. I love the wheels, but this drives me crazy when taking off, putting on the wheels. I had to have one replaced when they were first installed because the installer didn't do this and messed up the wheel by allowing the washer to be loose and hit the wheel as he tightened it, causing the washer to bind on the wheel and mess up the chrome.
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Yes, picked up on that right away. Don't think I'll ever let anyone mount one of these wheels. After putting the wheels on once, I'm not a fan of unilugs but maybe it gets easier with practice.
    This seemed like a good discussion on unilugs. http://www.stangnet.com/mustang-forums/423652-cragar-ss-wheels-unilug.html
  3. tody
    tody Member
    cologne, germany
    i found out today how exactly the t-bolts on the steering column work. i was pretty worried about the slop in the column and the collar before. now everything is tight as it should be :yup:
  4. bmxkrisv
    bmxkrisv Member
    ojai,ca
    70 mav
    about to fix my dirver side window...again!:mad:
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Took the last two days off of work so I could put my new transmission in... and yes I have some pics, and surprising enough i had to do less fabrication then I initially expected.
  6. 70prplmaverick
    70prplmaverick New Member
    Detroit Lakes Mn
    70 maverick
    lil by lil
    I pulled the front fenders, hood, and the old 200 6cyl out so i can start to clean up the engine bay and prep. for the 5.0 ho and supercharger
  7. whitey68
    whitey68 Member
    springfield illinois
    71 comet gt 65xxx orig miles .. 69 mercury marquis 2dr hard top land yaught, 62xxx orig 2 owner 429 4bbl 2000 heritage softail
    i found out that stevie wonder and helen keller did some wiring under the dash, spent a couple hours fixing that:rant2:
  8. doncraft
    doncraft Member
    Monroe WA
    1970 maverick 68 Ranchero
    funk
    You all know how it goes when building these car with every step you have to reinvent something so with updated four wheel disk brakes I have to go get more adapter fittings to make thing work and have to pull the drivers side header to reroute one of the header tubes so the pitman arm will clear so I got kinda bummed now Mavmet is building a 72 grabber and I'm building a 70 base model and where near the same place in our builds we call each other ideas and moral support he called and could tell I was bummin so he said why don't you build that Gage pod you been thinking about to get my head out of the problems and do some other little project now I'm old and need big gages to see them and I wanted to have them point at me from the package tray so heres how it came out.
  9. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    Looks very nice. and this is completely off topic, but that looks exactly like the radio i just pulled from my car...any idea what they're worth?
  10. doncraft
    doncraft Member
    Monroe WA
    I don't know what there worth:hmmm:got to be worth something to some one. I'm going to switch mine out to something more modern, have another face plate someone already cut up
  11. 75 Vomet
    75 Vomet Member
    Shickshinny, PA
    75 Comet GT, 03 Ranger, '11 Fusion,'13 Escape S
    Pulled out the original fuel tank and removed the rear bumper. I thought the rear bumper was decent, but it's just a pile of rust. Good thing I recently picked up a doner Comet with good small bumpers.
  12. Jsarnold
    '72 Sprint
    Got the new chrome 15X7 Cragar SSs and BFG Radial TAs on the car and cleaned up. :dancing:
    The 4.125" backspace works well with the 235/60/15s on the back. Can almost get a finger in between the tire and the leaf spring and it looks like, if the body ever goes down that far, the tire will miss the fender lip by about 1/4". Gotta take it for a ride to check for rub on the 205/60/15 front tires with max turn but I don't expect any problem.
  13. blugene
    Looks awsome! PLEASE don't forget the calendar :)
    Just an idea. Has anyone taken a string and pulled a line from the face of the rear tires and gone up past the lip to see how close it rides? I know that my differential sits closer to the right side than the left. Not by much but enough to tear the sidewall off if I'm not alert to the situation. I also overthink things too. I can only imagine that if my tires are in so much force that they go that high, how far side ways will it also go? :huh: I am sure I am not the only one who has lost new tires to the fender lip and it really sucks when it happens.
  14. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    You are not the only one...
  15. Jsarnold
    '72 Sprint
    Haven't done the string from the lip to the bottom of the tire but that's a good idea. I agree, body could move sideways if its down that far. I re-did both rear quarters in that area, including outer wheel wells so sides could vary a bit.
    No rubs on the front tires.
    Spoke to my neighbor about another photo. This time he wants to be paid -- tomatoes from my garden. ;) Will try to get it done soon.
