  1. wgs226
    wgs226 Member
    westminster colo
    1977 maverick
    I put on a set of helper springs to raise the rear end and give the car a sportier look:bananaman
  2. Earl Branham
    Lugoff, SC
    Got the parts together and started repairing the bad rocker/spring/lock/retainer on #2Exh. Came real close to losing a good engine over this thing. Glad it will finally get done.
  3. Shorty
    Shorty Member
    Lafayette, In
    I just ordered long wheels studs, open lug nuts and a brake proportioning valve from Summit. Yesterday I ordered a disc/drum master cylinder and push rod. This is all in preparation to putting the disc brakes I bought from 'Joe Dirt' on my car. The power steering is coming out too for the manual gear I've got ready to go in.
    Bruce
  4. bmxkrisv
    bmxkrisv Member
    ojai,ca
    70 mav
    I replaced both leaky rear wheel cylinders and bled my brakes.
    "I am sure I am not the only one who has lost new tires to the fender lip and it really sucks when it happens."[/QUOTE]
    i've had two rear tiers get the sidewalls eaten (foget which sides) now I have skinny tires:(
  5. Joe Dirt
    Dodged 2 teen girls on cell phones while trying to drive to work this morning. One was trying to merge on the interstate while texting =0
  6. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    Sounds like a fun drive to work...:oops:
  7. 71gold
    NOTHING...too hot....:whew:
  8. mercgt73
    Making window seals... [​IMG][​IMG] [​IMG]
  9. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I dismantled the front clip. Getting ready to strip the engine bay and do some sheetmetal patching......"Oh Thank You Jesus" for Air Tools. It was 109 today.:pub:
  10. bmxkrisv
    bmxkrisv Member
    ojai,ca
    70 mav
    I applied excess pressure to the skinny pedal and shaved a layer of rubber from my back tires:chirp:It was extra weight anyhow!
  11. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    I thought i was going to drive the maverick home but radiator started poring out coolent so now time to buy an aluminuim radiator Any suggestions? I found the jegs aluminuim for 179.99 and then 159.99 for the fanshroud that covers the radiator but leaves only the whole for the electric fan which is included
  12. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Got my trans temp gauge installed. With air temp in the high 80s, and about a 30 minute drive with a few WOT runs in 1st and 2nd, the gauge got as high as 195*.
    One interesting thing, to me at least. The Auto Guage had three terminals: Sender, Switched 12V, and Ground. At first I didn't connect the ground terminal and the gauge read WAY high, like 2X degrees F. When I could hold my hand on the trans pan the gauge was reading over 250*. Not sure why it needs a ground terminal but it does. Readings seemed reasonable with ground terminal grounded.
  13. Dave B
    I bought a real nice WC T-5 for my project car, didn't even have to clean it.
  14. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    You should just go get the tremec you mentioned:clap:
    Me im just trying to tie up all the loose ends on my tranny swap.
  15. Dave B
    I've been trying to buy it for a year...give them another year, and it will be mine.
