  1. stumanchu
    stumanchu Stuart
    Portland, OR
    Is there a drop bracket that actually doesnt self destruct?
  2. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Gives me an excuse to buy the integral PS box from ABS brakes.
  3. mojo
    I had the same issue about 5 years ago where my support broke away from the chassis and I had a much heavier bracket than the bolt on , on ur car. Don't have to worry about that issue now.
    stumanchu likes this.
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    Someone welded something very similar onto mine. Very heavy duty now.
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    are those bolt heads above and to the left of the visible portion of your bracket part of the deal? Your bracket has extra length, and seems it would prevent the ram tearing at it front-to-back. How much of it goes above the bottom of the frame to eliminate a tear side-to-side?
  6. apdlmike
    apdlmike Member
    74 Maverick
    Old radiator sprung a pinhole leak, figured it was as good a reason as any to bite the bullet and get an aluminum radiator/shroud/electric fan combo. Which of course means upgrading the alt too. A little annoyed that Champion didn't actually drill any holes in the shroud for mounting fan to shroud or shroud to radiator, but that's solved easily enough. Got a new A/C selector switch to throw in as well, can't wait to get that in there.
    Has anyone fabbed up a triple gauge pod that fits in the stock radio cutout? I think that might be the next item to check off the list.
  7. mavgrab302
    Swapping out the top end of my older 302 for a set of 289 k-code heads. They have screw in studs, fresh springs and roller rockers. I might update the cam while it is torn down. Going to top off the Edlebrock intake with a street demon 625cfm. The transmission is a TCI street fighter C4. This combo is going into my 72 Sprint...
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    I had a similar combo but mine were heavily ported with bigger valves and angle milled. The engine ran very strong due to the added compression. 340'ish horses with only a medium sized 220° cam. If you are interested I have a new cam research custom solid cam that was made for my combo which I would sell you VERY cheap. Solid cam/lifter combo deal is a bit on the rowdy side with .510"/.520" lift 224/229 @.050" on a 109 LSA. Was going to use it on my newest combo but am just biting the bullet to go full roller. If you're not interested I'll eventually just put it in the FS section later on.
  9. mavgrab302
    I have no experience with solid cams, are they ok with just a daily driver ? I do know that you have to stay on top of the valve adjustments.
  10. mav_man_71
    mav_man_71 Member
    Brighton,Ontario,Canada
    Bought some freshened up GT 40 heads, ford B351 roller rockers and a E303 cam to go with my weiand steath intake and holley 600 carb. it should wake up my some what stock 5.0 a little.
    mavgrab302 likes this.
  11. Dwarvey
    Dwarvey Member
    SoCal
    71 Ford Maverick
    Actually it was yesterday, but I got the disc brake spindles ready to install.
    Paul Masson likes this.
  12. falkon
    falkon Member
    Winchester, Va
    76 Maverick, 61 Falcon, 72 M151A2, 03 F150,
    Removing the air pump and emissions cleaning up the engine
  13. 7D2 Grabber
    7D2 Grabber Member
    Ordered the remainding AN fittings and hose to finish up my fuel system. Went aeroquip startlite and black aeroquip fittings in the engine compartment and the classic red/blue underneath.
    Made a little bracket from 2 body washers to hold my bulkheads.
    The startlite stuff is so easy to work with. No more chewed up fingers from the stainless crap.
    Drew Hierwarter and Paul Masson like this.
  14. Drew Hierwarter
    Drew Hierwarter Member
    Kingsport, TN
    1976 Comet
    I did a little more body work on the Comet today. Getting rid of the ugly aluminum belt line trim.
  15. 7D2 Grabber
    7D2 Grabber Member
    This little beauty showed up.
