  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Began the cleaning process on the bottom of the car, what a PITA! The oscillating tool works pretty darn good then I can follow up with the 4" grinder with a wire brush. Even with power tools it sucks! I may roll it outside to use the sand blaster on the hard to reach spots.
    Paul Masson likes this.
  2. 71Mavrk
    71Mavrk Member
    Nevada
  3. Drew Hierwarter
    Drew Hierwarter Member
    Kingsport, TN
    1976 Comet
    Well, this isn't so much something I did to my Comet, but something I did for my Comet, okay, actually for me to make it easier to work on the Comet. They just opened a new Harbor Freight store here and I got this welding cart for less than $50.00.
    No more lugging the welder and bottle around the garage!
    7D2 Grabber likes this.
  4. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    I joined this forum over 2 years ago with my 72 Maverick project, and today I can say I am finally done (with a lot of help from everyone on the forum)! Yes there is lot's more that can be done, but this car is finally formally ready for the road and shows. Everything else can wait. I just hope I don't get into the engine like many on this forum or I will never retire. It's also a friend to my 51 ford pickup (colors don't go well, but it works.). This finishes the auto restoration for my lifetime!
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    That is a beautiful Maverick! I bet it feels good to be done.......but if you park a white car between those two, all three would look nice.:p
  6. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Surrounded by new parts, but can't get any free time to get any work done... :(
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    I sure do hear that!
  8. scs
    scs Member
    Prescott wisconsin
    A big 8 mpg at 60 mph, something has got to change.
    Paul Masson and NCFatBoy like this.
  9. apdlmike
    apdlmike Member
    74 Maverick
    Finally got the replacement radiator installed. In case anyone's wondering, if you've got the double V belt pulley system, you're gonna have one hell of a time trying to install any kind of fan. The champion EC339 radiator went in, but the shroud was too much - any fan bolted to it couldn't clear the water pump pulley. I had to remove the shroud and get a skinny fan from Summit and fashion a crude mount with some metal strips and ties. Not too pleased with that ordeal, but at least she runs.
    Next I'll have to fix the exhaust leak. Hopefully it's just the gasket, because it seems more or less impossible to find a header that'll fit a 250 with AC and PS. Without altering the mounting brackets, at least.
  10. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Finished up my fuel lines.
    Started taking out the old front power ram and laid out the new stuff I got.
  11. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Installed my Clear Turn lens I got from/gregmaverick
    Look great
    Also installed battery box and gel battery but have some rust to take care of under battery
  12. mavgrab302
    For the first time since I have owned my Grabber, it now has a horn. They are a set of high and low pitch I bought from NPD $31 bucks.
    NCFatBoy likes this.
  13. apdlmike
    apdlmike Member
    74 Maverick
    Replaced the plugs, rotor, cap, wires, coil. Now no spark. Put old parts back on and still no dice. Time to grab the test light and go fishing.
  14. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Got in it and fired it up. Haven't ran in two weeks so I went for a drive and barely missed a deer... Now time to build a fan shroud for it.
  15. stumanchu
    stumanchu Stuart
    Portland, OR
    While working on routing some steel trans cooling lines, I found this tag on a coil spring (yes, I had to briefly consider running the line through the shock tower). Factory or aftermarket? Anyone know? WP_20160523_18_37_48_Pro.jpg
