  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    Got my new wheels and tires put on
    NCFatBoy likes this.
  2. 71gold
    I have pulled the heater boxes on several cars , reached in and removed all the pine needles and leaves.
    on Patches, I did as Cometized suggested and sealed the cowl.
    SupermanEst1984 likes this.
  3. Howard Forbes
    Howard Forbes Member
    Chesapeake, Va
    1972 Maverick , 1977 Cobra II
    This is a 2016 Viper Competition Blue color. I'm not sure if it is exactly what I had in mind. Thought it was going to be closer to Grabber Blue . Any input ?
    NCFatBoy and Paul Masson like this.
  4. stumanchu
    stumanchu Stuart
    Portland, OR
    My cowl doesnt leak....but I have been wondering how to clean it out without removing the cover. I also was wondering if there was some way to pour rust converter into it, or spread it through there with a sponge.....how much access is created with heater box removal??? I know this is bordering on a new thread, but curious minds (mine) really, really, want to know.
  5. blvd2583
    blvd2583 Member
    sheboygan falls wisconsin
    1972 mercury comet
  6. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    You can take ospho and use a small tube to pore it in. You can also take a small capful and reach up through the air intake under the dash and pour it around.
    stumanchu likes this.
  7. 71gold
    took Patches for a...:drive:...:chirp:
  8. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi again Stu:
    You can clean out the area you've mentioned from the " SIDE " and " Prep" the inner areas of the cowl with a good rust inhibiter ( OSPHO) which is low priced and available at most all ACE Hardware stores .. The OSPHO can be applied with a spray bottle and some cheap paint brushes. After the applications of OSPHO .. let it ' cure ' a few days then apply some POR black paint to the areas you can reach . I have a small clip on the CAMEO website that shows most of the steps I've described if you'd care to peruse the article. The website is www.cameoclub.com in the Restomod/Improvements file. Click on that if you'd like to see more. This forum also has articles on dealing with the same subject which would help you immensely . I wish you success on whichever steps you take .
    Cometized
    (Chip)
    NCFatBoy and stumanchu like this.
  9. mgabski
    mgabski Member
    1973 Maverick
    Did you do anything to the shock towers? And what headers are you running. Looks good
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    Polished front bumper, painted "rusty" side with POR15. Soaked bolts and brackets in a concrete mixing tub with 3 gallons of white vinegar to de-rust.
    71gold likes this.
  11. mav man
    mav man Member
    wi
    70mav
    Why didn't you just notch the fenders on both sides like on small bumper fenders?
  12. stumanchu
    stumanchu Stuart
    Portland, OR
    I dont know how the small bumper fenders are notched....and I thought I had less material to remove the way I did it. I was afraid too cut too much, so I paid for that with filing, but I got a nice fit in the end.
  13. SupermanEst1984
    SupermanEst1984 Michael Myers
    Monroe, NC 28110
    '72 2 door Ford Maverick 250 6 Bangin' it
    Will be doing this when I can afford the right stuff to seal it (not to mention I can always use Por15 practically every where else on the car) and I Definitely will be without cowl vents :D because once it's sealed they will be welded and I have been figuring out possible ways to seal the wiper posts when they're not in use but can be quickly when they're needed.
    Sandblasting brake calipers today :spam: I hate it but the white metal parts are coming out purrrtay for just having a rattle can primer and silver metallic paint sprayed on'em
  14. the muss
    the muss Member
    norway
    1970 maverick with 351 w
    Almost finished the new fuel line and trying to check "everything" so the car is ready to be shown to the goverment for license plates
  15. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Had not heard of OSPHO. Thanks!
