  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Bought a 347 with steel crank, H beam rods, SRP pistons, Aluminum heads and a TKO 3550 with scatter shield for the Maverick!!!:bananaman:
    stumanchu, Krazy Comet and yellow75 like this.
  2. stumanchu
    stumanchu Stuart
    Portland, OR
    YAHOO!!!!! that sure beats buying P&P junk to upgrade with!!
  3. RMiller
    Kennewick, WA
    Absolutely! I have a low mile 5.0 with roller cam out of a Bronco but this came up and I couldn't resist. It's all used but I'm getting it from a very good friend that, doesn't do things half way. He's liquidating inventory so he can buy a Boss block for his Fox Mustang, the car runs 11.20 with a Vortec blower on the 180,000 mile stock bottom end. This is the current motivator to work on the car again, looking forward to getting it home so I can sit and stare at it!
  4. Tannersg1
    Tannersg1 Member
    Classified
    This.... 18010498_1175954002530577_8646547511928642189_n.jpg 18034013_1179731712152806_724551203004158198_n.jpg 18034335_1179731742152803_3242628491520890167_n.jpg 18222512_1192086357584008_1659736292820841139_n.jpg 18275014_1191879397604704_1045384250517479387_n.jpg
    mavgrab302, 71gold and yellow75 like this.
  5. RMiller
    Kennewick, WA
    Nice job, that looks great!
    Tannersg1 likes this.
  6. Scooter71105
    Scooter71105 Member
    Shreveport LoUiSiAna
    Got the stinky carpet out and in the trash. Already smells better. My wife is almost excited as I am about this project.
  7. Tannersg1
    Tannersg1 Member
    Classified
    Thanks!
  8. Howard Forbes
    Howard Forbes Member
    Chesapeake, Va
    1972 Maverick , 1977 Cobra II
    Doing the last bit of wiring and got the digital dash fired up.
    mojo and Tannersg1 like this.
  9. yellow75
    Tillamook Oregon
    Well after working on the car off and on for a couple months changing gears, changing valve body, changing headers, changing starter, changing shocks, changing alternator, painting various parts and doing a Taurus fan install I finally got to the point that I was able to start the car and test everything. Let the car sit and idle until temp came up to 200 then the fan kicked in on low and took temp down to 170 and turned off, just a little on the high side from what the switch in thermostat housing was rated at to kick in 195. I then flipped the on off on switch to high and temp just kept going down, temps were not very warm outside but just sitting and idling it would have heated up before so I am very pleased with the outcome.
    I highly recommend the Taurus fan mod its not that expensive to do and hopefully wont leave you stuck along side the road waiting for your car to cool down and moves a lot of air when you are at a stand still. I am going to get a couple spare parts such as the fan relay but in a jamb you can jury rig it to work as long as the fan does not die.
    The one problem I encountered was all the wiring that had to hook up to the starter solenoid hot side, I have 6 separate wires that hook up to it, so I made a little copper bar and bolted 3 wires at one point and 3 more at another hole that I drilled in the copper bar. Looking for a cleaner way to do it any body else ever run into this problem ? Any ideas to cure it ?
    Wires at the starter solenoid are battery hot, alternator hot, fusible link, stereo amp, starter hot (high torque mini starter) hot for Taurus fan. I already have 2 wires that hook to the battery terminal clamp MSD 6AL and stereo memory
  10. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Are you using the stock radiator? Or a champion?
  11. yellow75
    Tillamook Oregon
    Champion 3 core
  12. 71gold
    Hi Mike, what I did was I found a power bar with 6 terminals on it. I wired a 10 ga. wire from the batt. to one end and hooked my accessories to the other 5. it's mounted to the frame next to the starter. I looked for a pic but I can't see it in any of my motor pics. I guess I hid it pretty well...LOL
  13. yellow75
    Tillamook Oregon
    Frank that's what I will probably do in the future, guess when I see Patches I will take looky see
  14. RMiller
    Kennewick, WA
    Picked up my engine and transmission after work. The transmission is a TR3550, not TKO, I knew that and have no idea why I typed TKO in my previous thread. Before I get to spend any time play around with those I need to finish a couple items on the Firebird so we can send it don the road. After that I will paint my Harley and it too might find a new home, that's money that could really move the Maverick forward (Harley sale).
  15. stumanchu
    stumanchu Stuart
    Portland, OR
    I just test fit my stock 3 core radiator with upside down Taurus fan attached. It hits the bottom pulley (3 belt pulley). I need to switch it out for a two belt pulley. I dont have AC, just used that pulley because it worked. I had to move the radiator 1 inch to the passenger side to miss the water pump pulley. I better find out which way the engine moves when it grunts.
