  1. Powerband
    Powerband Member
    NY's \H/
    Since snow receded I got out to the barn and hooked up Battery trickle charger until Spring...
    have fun
  2. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Thank's look very nice
  3. TC87
    TC87 Member
    SC
    69.5 Maverick
    Not necessarily to it, but picked up an 8.8 with 3.73 limited slip and disc brakes out of an Explorer today with another short axle shaft. Plan on getting it torn down, cleaned up and cut this weekend.
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    Reinstalled my oil pan, timing cover and water pump
  5. 2mav4u
    Tolleson Az
    Removed master cylinder and all hard brake lines, and installed clutch pedal. Clutch pedal was a PITA. Can't really tell from the pic but the "rusty" support has the bearing upgrade.
    mavgrab302 likes this.
  6. mn67
    mn67 Member
    Great white north
    Stared at it in the 18 degree garage and then ordered more parts.
  7. Krazy Comet
    Brrrr
    I took a ride Sat, was 67* now 40* & raining... Maybe snow tomorrow...
    mn67 likes this.
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    I look out the window everyday...... looking forward to when the rain stops and the sun comes out.
  9. yellow75
    Tillamook Oregon
    Stu, you had your chance yesterday, now you have to wait a couple more weeks. I know the feeling brother we have had a wet year here on the coast . I spent the day yesterday going to the NWDRA high performance swap meet, should have stayed home and enjoy the half day without rain.
    stumanchu likes this.
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I just walked out and it's raining here but... I will take that any day over the snow we had last year!
  11. 71gold
    took my new oil change for a :drive:...:chirp:
  12. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    I replaces the axle seals, installed the axles, backing plates and wheel cylinders. Also hung a new center brake line but didn’t bolt it the axle housing. The new centric brake line union is a lot thicker than the old one. I’ll need to get a longer bolt. After I pinched down the c-clip at the hard-line I noticed the line doesn’t reach the axle housing. I think it’s because there is no weight on the springs. The car is supported at the unibody. How long should the centric brake line be? Maybe I bought the wrong one?
  13. mn67
    mn67 Member
    Great white north
    Had a rendering done for build reference.
  14. 71gold
    went for a...:chirp:today. got into it kinda hard and when I got out it wouldn't idle below 1730 RPMs. I was a couple of miles from home so headed back. had to shut it down in gear and at that it wanted to run on.
    pulled the breather off and a piece of the breather gasket was sticking down in the throttle body. it was holding one of the butterflys open. I had to open the throttle to get it to release.
    I'm guessing it got sucked in when I got on it hard.
    it will be back in the streets tomorrow and we will try it again...:drive:...:chirp:
  15. Hotrock
    Munroe Falls, Ohio
    Frank, that LS engine must really suck!!! LOL
    Have a great day.
