  1. 71gold
    LOL...
  2. 71gold
    put a new breather gasket on...:drive:...:chirp:every thing is lovely...:burnout:
    it was in the 70s today so I had a chance to check out the A/C...:thumbs2:
    being they are calling for rain tomorrow, when I got home from my ride...I mowed the grass...:yup:
  3. Hotrock
    Munroe Falls, Ohio
    Stop it!!
    Snowing again this morning at 8:10, 22 degrees F.
  4. 71gold
    22 degrees F. would be too cold to snow in Ga. (upper 40s to mid 50s):yup:
  5. Krazy Comet
    It snows at 40*-50* in GA??:bs:
  6. 71gold
    I guess you didn't read the joking in that statement...:biglaugh:
  7. mavgrab302
    Got the Global West upper and lower control arms and the Viking coilovers installed on the drivers side, also new Moog inner and outer tie rods. tomorrow I will do the passenger side, then set my ride height.
  8. 71gold
    going to Summit today to get some of the parts for my 9" build...:party3:
  9. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    I tried to get the bell housing alignment pins out of the block. The emphasis is on tried, no luck yet.
  10. 71gold
    went to Summit and got another load of 9" parts. started cutting on the 9" donor tubes.
  11. yellow75
    Tillamook Oregon
    Started parting it out
    The 75 Maverick parts car I brought home, #57 I believe. Down to about 1 a year these days getting harder to find
    Craig Selvey likes this.
  12. 71gold
    disassembled the 9" chunk, steam cleaned it, bead blasted it, steam cleaned it again and dropped it off at the powder coater today... should be ready tomorrow.
    now to clean up the housing...:bouncy:
    gonzoayres likes this.
  13. gonzoayres
    gonzoayres Member
    Honolulu Hawaii
    1973 Ford Maverick 250cid 6cyl automatic 2 door
    ordered my exhaust gasket, took off the headers, started cleaning off the old gasket from both surfaces
  14. stumanchu
    stumanchu Stuart
    Portland, OR
    Last fall I purchased a very low mile Holley 4160. I went through it to return it to factory specs, do preliminary float adjusments, etc. I installed it today, and it seems fine. Cant road test yet, but is almost 16 in. vac at idle, and drops to 13 with a quick recovery when primary is opened rapidly, will not drop at all if opened fairly slow, and Idle screws are very responsive. Runs smoother than previous 1850, and the throttle shafts arent wore out. Cant wait to see how it will run at WOT........and of course....at all points in between!
  15. mavgrab302
    I finished my install of the Global West upper and lower control arms. Set my ride height on the Viking coilovers and got the alinement close enough to drive it to the alinement shop.
    71gold likes this.
