  1. stumanchu
    stumanchu Stuart
    Portland, OR
    I went to the junkyard to find a window motor for the wifes car, and also found some junk with a C4 in it. It had an H servo, so I bagged that cause I heard they were good for something. I started my car today after adding oil....new pan gasket doesnt leak yet....let it run for almost 10 minutes. Blue felppro one piece with a dab of sealer on the corners of the main caps. :bananaman:
    71gold likes this.
  2. 71gold
    ordered a 3.25 gear for my 9"...:drive:...:chirp:
  3. stumanchu
    stumanchu Stuart
    Portland, OR
    3.25 with O.D.? I suppose you had 930 miles to think about it, but at cruise will your exhaust note be tame?
  4. 71gold
    with my 1500-5500 cam it will be 2100ish RPMs at 80 MPH. I think that will be fine.
    Wilbur Green and mojo like this.
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Frank:
    Read your post about the 3.25 Gear . I've had one in my Comet with the 408 Fuel Injected and Tremec 5 speed to a 9" Rear End and on the last HRPT I averaged 21-22 mpg. Not too shabby for a performance engine setup. Still has
    plenty of Bottom End and Cruises at 1900 - 2100-RPMs and 75 MPH on the highway. Great Gear !! The 70 Maverick has stock 5.0 fuel injected and 5 speed tranny ( Not Tremec ) and got 24-25 MPG at the same speeds.
    Cometized
    (Chip)
    71gold likes this.
  6. mojo
    What gear u running now? 2100 @ 80mph sounds like new car territory -- I like it!
  7. 71gold
  8. Earl Branham
    Lugoff, SC
    Fixed the ignition switch on my Mav. Just a worn nub on the spline that locks in the switch, causing it to turn when you turn the key. Agravating, but not damaging. Just filed it square and installed it as tight as it would go.
    mavgrab302 and 71gold like this.
  9. 71gold
    ran in my new gears....:drive:...:chirp:
    Earl Branham and mavgrab302 like this.
  10. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Got a much needed alignment.
  11. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Still working on some stuff to hold tools for the maverick, will see how the tool box end , is a must
  12. M7A7V
    M7A7V Member
    Oakville, Ontario, Canada
    77 Maverick 2dr, 77 Maverick 4 dr (no longer own)
    New front shocks on the 4 door. The old ones had zero rebound and the rubber was dry rotted. Rides like a new car. I also removed the gas tank from my 2 door. 15 years of sitting was not kind to the inside of the tank. Going to need a good clean out before fresh fuel.
  13. 71gold
    I like your screen name...:thumbs2:
  14. Miguel Arzola
    Long Beach Ca.
    O most finish my Body Work storage tools spray guns will be on top everything in one place , all for the maverick Hobbie
  15. Earl Branham
    Lugoff, SC
    How do you like the new gears?
