  1. stumanchu
    stumanchu Stuart
    Portland, OR
    Double post....I dont know how to delete.
  2. Krazy Comet
    Dismal Swamp
    Sounds as it's adjusted correctly.
    The rod insures trans will downshift when floored(up to approx 60-70mph), otherwise dependant on modulator valve temperament, downshift may or may not happen. I ran a Ranchero for years without kickdown, could blip throttle and it'd downshift up to about 45, I got used to manually downshifting.
  3. mavgrab302
    Added LED headlights to my mav, they are bright...
  4. Earl Branham
    Lugoff, SC
    Attempted to cut the shroud on my newly ordered Taurus fan assy. Got it cut, taking great care not to touch the fan, lest I bend the shaft and throw it out of balance. Got it cut, moved the fan a few turns to see if it was good......it was not. The fan touches on one place on the shroud, and I don't know if I can make it work. Anyway, thought I would see if the shroud was good and if it was going to fit right. It did not.....shroud on the VDO fan is about 3/16" larger, and moved it that much closer to the water pump pulley, which is about 1/16" too far. I'm gonna remove the upper hose and see if it is just me. This has been frustrating to say the least, but at least its moving forward. If I get another fan, I'll be sure to get a stock Taurus unit and try again. Wish me luck!
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    I have a ford 3 core radiator, and the fan barely fit in my car with shaving the shroud, I think on all four sides. I also moved the radiator to the side a little .....as I recall, there were some extra holes in my core support and I had to only drill 2 new ones. I used a junkyard taurus fan, so it was not aftermarket. I hope you get it in there!
  6. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    I have a 3 row with the Taurus fan mounted up side down. I gently masaged the mounting holes on the rad cradle forward about an inch ( not for the faint of heart) and this is how it ended up. comet elect fan install 021.jpg
    Krazy Comet likes this.
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Plenty of Room ! : )
    Cometized
    (Chip)
  8. Tannersg1
    Tannersg1 Member
    Classified
    Removed rear springs and differential to prepare for the tubbing.
    mavgrab302 likes this.
  9. Earl Branham
    Lugoff, SC
    I got the fan to fit, and it works well, at least it works as well as the original one did. The volts drop below 12v when the fan comes on low, about 11v on high. I guess next is the battery and alternator. I'll track this gremlin down yet, but not till after his hurricane goes away, and see what I have to do when that happens. BTW, all of you eastcoasters be carefull, be smart and come out of this in good shape!
    stumanchu and Maverocket like this.
  10. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hopeful that you'll ' miss ' the path of the hurricane .. Incidentally .. an alternator with a greater capacity is a good
    idea . I run the AC ' All The Time ' down here in Florida so we changed ours and it really helped.
    Cometized
    (Chip)
  11. Earl Branham
    Lugoff, SC
    Chip, I am running a 3G alternator, 95amp from a 1996-2005 F650 truck. I chose it because the form factor is exactly like the stock alt. Its been in the car for over 10yrs, so it may be time to check it out. Advance Auto Parts put their checker on it and the battery, said both were good. I'll wait till this storm passes and get on it again.
    Take care,
  12. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Earl:
    WHERE are you testing the voltage readings.. Inside the Car ?? Outside under the hood ?? The alternators I have
    on our cars here are 125 AMP units .. and my Daughter has a 110 without any problems. Lemmeno about the reading locations. It will make a difference .
    Cometized
    (Chip)
  13. Earl Branham
    Lugoff, SC
    I am reading the voltmeter inside the car. I checked the battery, with the engine running, and it read 14v. When I turn the a/c on, the voltmeter inside read 12v. Haven't had time to read at the alt yet, doing hurricane preps for tomorrow.
  14. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Well today I work a little more in the roof , I know this mavericks are a challenge for us but hope I'm in the right pat 8 more hours poss the roof will be done
    mavgrab302 and Krazy Comet like this.
  15. 71gold
    replaced a tail light mini fuse today...:bouncy:
