  1. Hastings1066
    Hastings1066 Member
    Alabama
    1976 Maverick
    I pulled the I6 and tranny out. Start dropping in the 302 tommorow!
  2. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Got the shock tower notch started on the passenger side of the '75, along with the shelby drop on that side. Test fit the 5.0l HO to see if I can use the '92 Cougar HO shorties before I welded it all back in, looks like they may fit if I can fit up the exhaust. Won't know until I notch the drivers side on the next trip up to the shop.
  3. 71gold
    got the alt. cable ran to the trunk w/150 amp breaker...all is good with that.
    now I think the ignition switch took a dump...:slap:
  4. Tannersg1
    Tannersg1 Member
    Classified
    56119560_1969913849801251_3450334463681101824_n.jpg A little cowl repair in progress. The pipe flange was used to keep the cowl hat round while I bent the flange.
  5. 71gold
    went to Summit today and got a new ignition switch...$20.99
    it didn't correct my problem.
    to start and stop it...
    turn the key to the on position.
    go under the hood and hit the bump button to start car.
    turn the key to the off position.
    go to the rear and flip the kill switch.
    ...:yup:...
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    Do you have a stuck relay somewhere? I am sure your wiring isnt stock.....
  7. 71gold
    thanks...I was going to check one of the relays tomorrow...:Handshake:
  8. Earl Branham
    Lugoff, SC
    Brought the car home from the shop, and the mechanics at the shop say they can't reproduce the problem with the fans. I guess I will have to take it out and shake it down, and see what happens. The mech says he thinks it was moisture in a relay or contactor, but can't prove it. It has rained so much down here, that I can see how it could happen. It's raining now, so maybe tomorrow I'll take it out and see. He tightened the sway bar ends, and checked it over. Seems to be ok. We'll see!
  9. Earl Branham
    Lugoff, SC
    Ain't all this pre-summer thrashing fun?:rofl2:
    71gold likes this.
  10. Warp9
    Warp9 Member
    Simcoe Ontario Canada
    1972 Ford Maverick Grabber
    Picked up my new leaf Springs today. Install tomorrow. :comet:
  11. Krazy Comet
    Just move the bump button & kill switch to dash, problem solved. :tiphat:
    With electric fan(wired direct to switch) and electronic ignition my Comet was "slow" to cut off. Once I wired in a fan controller problem was gone.
  12. Earl Branham
    Lugoff, SC
    Took car out for first time since coming home from the shop. Shop owner said he didn't repair anything, so I made sure I had Hagerty's number, cell phone, and a little time. Took a 54 mile ride, but car didn't get hot enough to trip on the fan. When I got home, I let it run in the driveway for about 15 minutes, as it was about 180degrees. When it hit 185, fan came on as it should, ran just right. I'm gonna take it out later and see how it goes with a bit warmer outside temps. This is nuts, and its hard to trust the car will get me home. So it goes...….
  13. yellow75
    Tillamook Oregon
    Earl you need to go out and get stuck in a traffic jam with stop and go driving, if anything will make it heat up that will . Seems to me that I have never had a car that hasnt given me heating issues no matter what I have done to stop it, Taurus fan has been about the best thing that helped me
  14. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Played with my blast cabinet, finally got it up and running. I figured I might as well attack my control arms and see how it does. Cleaned them right up and I sprayed them with etching primer.
  15. 71gold
    along the same lines...
    Effie had a check engine light come on Fri. on her Sport Trac so I stopped by an auto parts store today and had it scanned.
    ...temp sensor...reading too cool...:huh:
