  1. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Well today I work in the rear end finish Installing the bearings and try to repair the back brake plates had a groove in it where the brake shoe rest and slide coming along ok
    71gold likes this.
  2. Miguel Arzola
    Long Beach Ca.
    Little bit of work
  3. 71gold
    :thumbs2:...
    Dyent, just mentioned this repair in a front brake thread yesterday.
    Miguel Arzola likes this.
  4. Krazy Comet
    Common sensor failure, computer thinks engine is cold even though it could be overheated(not likely). Though this condition could prevent fan from activating causing, yep, overheating.
    Sensor went out on my F-150 and it'd flood when hot, had to hold it on floor(dechoke mode) to get it to start. Computer thought temp was -30*F.
  5. 71gold
    the temp gauge reads cooler than normal. I had replaced a leaky T-stat housing and the T-stat came with it. maybe it was the wrong temp T-stat...they come in 170/180/192/195 Degrees. I will see if I can find the box and see what temp this one is...thanks
  6. Krazy Comet
    The temp gauge SENDER and temp SENSOR for computer are generally two totally different parts(at least for most vehicles). If temp gauge reads approx normal and makes good heat, there's nothing wrong with thermostat.
    Temp gauge on truck was in middle of normal, still computer thought the temp was -30F.
  7. 71gold
    found the old T-stat...92 c or 197.6 f.
    new T-stat is 190F...:huh:
  8. Krazy Comet
    You may want to search net to see if 8* makes a difference, I'm betting it doesn't.
  9. 71gold
    I'm thinking it does.
  10. Krazy Comet
    Change it and see, but rarely does a stat open exactly at it's rated temp.
    In very cold climates engines rarely warm completely to stat ratings.
  11. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Put in new carpet from ACC.
  12. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I bought a hood with nice molding for $20:bananaman:
  13. Earl Branham
    Lugoff, SC
    Drove it around a bit. Ran fine, but the fan still pulls a lot of volts. Still checking!
  14. Krazy Comet
    What does pull a lot of volts mean?
  15. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Maverick_Ian90 and 71gold like this.
