  1. mojo
    mojo "Everett"- Senior Citizen
    I have never seen headlight, turn signals or anything else change from normal. Also, gauge goes to 14V from engine start and never change until I turn off igntion.
  2. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Removed the front windshield over the weekend. Whomever installed it previously used a LOT of adhesive. Also started to remove the dash board.
  3. 71gold
    changed a blown fuse in my brake lights...still no lights.
    I guess it's that Ghost at it again...LOL
  4. Krazy Comet
    Fix it like you did your kitchen light.
    Shine a flashlight on the lights(you'll need two), that'll will create a electrical vortex inversion, they'll start working again.
    71gold likes this.
  5. 71gold
    that was a minute ago...:thumbs2:
  6. 71gold
    ...:biglaugh:...
    Earl Branham likes this.
  7. Earl Branham
    Lugoff, SC
    I'm going to look into getting a bigger alt. I replaced the battery, the old one was 6yrs old. Any suggestions for an alt. that will fit the same form factor?
  8. Earl Branham
    Lugoff, SC
    :slap: Shoulda thought of that!!!!!
  9. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    I use the ford 3g alt off of the 1993 ford Taurus? It is very simple to install. You remove all of the factory harness to the voltage regulator and the regulator. You will need to get the alt, the harness (you can just buy a 3g harness) and you will need to make a new battery cable. Very easy to install.
    jasonwthompson likes this.
  10. Earl Branham
    Lugoff, SC
    Thank you! I'll check on the alt how mine is hooked up.
  11. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    Bought new headlights ,
    Digi tails Leds for the bobcat tails
    And pulled the trans to prep for
    Exchanging the clutch
    Pulled he bobcat tails off
    Installed the prototype ACP 1970 gas tank , an ordering some more parts
  12. William623
    William623 Member
    Orlando
    Digit tails makes a LED board for the bobcat taillights?
  13. Hastings1066
    Hastings1066 Member
    Alabama
    1976 Maverick
    Finally heard the 302 speak today!!!!!
    Krazy Comet and Maverick_Ian90 like this.
  14. 71gold
    got the Ford T-stat installed and no code, gauge back up to normal...:bouncy:
  15. Krazy Comet
    Then stat that was installed wasn't getting anywhere nearly hot enough. If it had actually been off by only 8*, there probably would not have been a needles width of difference in gauge reading.
    It had been OK for some time after last stat install?
