  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I’m thinking the best option when the time comes is to completely rebuild it with good components because you never know what you’re getting with a used trans.
  2. William623
    Orlando
    1973 ford maverick grabber
    0E422C18-DA47-474B-B1D0-4ED09DF672FD.jpeg 010C4FFD-8901-4ABC-BF14-000F3D73C812.jpeg
    A friend recently got a 69.5 parts car, so I traded him some parts for these goodies!
  3. Krazy Comet
    I rebuilt the 169 with new gears, year or so later,, - CRUNCH!!!! Busted 2nd on the cluster.. I rebuilt it again to 199 spec(the '90-'93 gear set) and it never gave another problem.
    As I've stated cases are different for the 4cyl trans, best bet is sell it and get a V8 version.
  4. BBMS18
    BBMS18 Member
    75 Comet
    Can you please elaborate on the “case difference”?
    Thanks
  5. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Bought some hardboard so I can start to replace the door cards.
  6. Krazy Comet
    As I've stated, the opening for input gear/shaft is machined larger on the 4cyl trans. Means the gear, front bearing and retainer are larger than V8. These mods were necessary to fit the stump pulling 3.97 first gear ratio into case. Last I checked, the larger retainer had been discontinued. Being aluminum they are often scored & reason the steel nosed retainers were developed for V8 versions(those should be available but do not fit the 4 cyl trans). The scoring causes throw out bearing to bind, resulting in a stiff(sometimes stuck) clutch pedal. Twenty plus years ago I replaced a couple on Turbo Coupes.
  7. BBMS18
    BBMS18 Member
    75 Comet
    I’m still confused.
    The gear on the input shaft is 4th, 1 to 1 ratio in both 4cyl & V8, 1st is the most rearward gear inside the main case and is installed through the top of the case.
  8. Krazy Comet
    You're correct, it's the gear on input shaft that meshes with cluster that's larger. Those gears effect all other gear ratios.
    BBMS18 likes this.
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    In fourth gear the input shaft drives the output shaft directly, the gear is irrelevant. The gear on the input shaft is only in play for all the other gear selections, it is the first ratio in the compound ratios that determine the final ratio of each gear (excluding fourth). I might have just confused myself!
  10. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Finally I’m done with the engine ,time again to work in the body and parts ,,,
    MountainDrre, mojo, yellow75 and 2 others like this.
  11. Krazy Comet
    WOW that's nice!!!! You're putting in some serious work!
    Miguel Arzola likes this.
  12. yellow75
    Tillamook Oregon
    So shinny, Mikey likes it
  13. RMiller
    Kennewick, WA
    Makes me feel like a serious slacker!
    Maverick_Ian90 likes this.
  14. William623
    Orlando
    Finally decided to fix my leaking windshield. Found out that the gentle man who previously installed it who had done several mavericks previously forgot to put back in the metal stands... He also did not use nearly enough butyl.... Both windows are back in and fully sealed.
  15. BBMS18
    BBMS18 Member
    75 Comet
    Not a darn thing.
    But I did have a chance to take this little beauty for a spin.
