  1. Earl Branham
    Lugoff, SC
    Hi Everett, I had the DuraSpark ll setup, which failed. I went to a Mallory setup, but didn't like it at all. Had to replace the module a couple times within a month, so it went away. I replaced the distributer and coil with the Pertronix FlameThrower pieces, and it was trouble-free for over 10yrs. Now, the module has died, or so says the Pertronix tech. I'll let you know how it goes. Hopefully, this fixes it and gets it up and running again.
  2. Krazy Comet
    It's surprising how many(supposedly) bad coils are out there. Other than over heating a couple because I ran without resistor, in 50+ years I've never had a failure. Check that, I've seen spark jump out the side of tower, but was still OK electrically.
    I'm somewhat suspect Pertronix quality has declined over the years. They say made in USA but where are components sourced?
    One in my Cobra Jet is around 25 years old, but I've carried points and condenser in the console from day one. Recently updated condenser as those fail more from age than usage.
  3. Earl Branham
    Lugoff, SC
    Well, distributor module, cap and rotor replaced, with no effect. Next thing will be the ignition switch circuit and wiring. This problem has me all tied up, but I'll get it soon.
  4. 71gold
    when it dies is there still power to the distributor?
    what say we move this to...
    Technical
    Earl Branham likes this.
  5. Earl Branham
    Lugoff, SC
    Found the ignition switch to be burned and melted on the pigtail connector. Parts are ordered, see if that is the problem. Sounds like it very well could be. If not, move to technical forum.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Got the car running and camshaft broke in, still need to fiddle with the carb on startup
  7. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Flushed all the brake fluid through the system. Vacuum bleeder for the win. Also, ground down some rust on the interior and hit it with reformer.
  8. WiscoMav
    WiscoMav Member
    Greenfield, Wisconsin
    Working on Wilwood front brake disc brake conversation. Need to bleed system still and get tires for my new front wheels.
    skin, mojo and Miguel Arzola like this.
  9. Krazy Comet
    I yanked off the electric fan that I've never been happy with, then reinstalled factory shroud & fan blade.
    Miguel Arzola likes this.
  10. Maverick_Ian90
    Northeast
    What rims are those?
  11. WiscoMav
    WiscoMav Member
    They are American racing Rodder Or VN507. I went with 17 inch x 7 inch wide. I don't have tires mounted up yet but hope to have it rolling again soon.
  12. Maverick_Ian90
    Northeast
    I was actually looking at getting a set of those. Let me know when you get rubber on them.
  13. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    Hi like to ask you how you like the Wilwood set up that all fit fine Or you encounter any problems with this set up !! Thanks
  14. mojo
    What you were unhappy w/ the e-fan?
  15. Krazy Comet
    It's always been borderline with cooling but to be fair, some of the issue may be the engine rebuild. With a orig type fan & shroud cooling defiantly improved, radiator was new when I installed engine.
    For some time I'd been thinking of trying a engine driven fan. What pushed me over the edge was driving the '69 Fairlane home from OH in upper 80s, it never spilled a drop of coolant.
