  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Why the hole, what setup are you running? I bought the Rosehill kit, I would need to make a hole for my scattershield so I'm getting a Ford piece to avoid that.
  2. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    been working nights which gives me ALL DAY to work on the maverick!
    today I was able to...
    - get the slave cylinder and throwout bearing/clutch fork installed and aligned on my bellhousing on the back of the engine.
    - routed the hydraulic line, welded up the clutch pedal to accept my clutch pedal push rod
    - got my headers in place.
    - took some backspacing measurements and spent some money on some wheels!..
    I went with these (https://www.visionwheel.com/wheel/896/VisionWheel/521 Nitro?finishID=2404) in 15x7 all around... i wanted to go 15x8 in the rear but I wasn't confident on fitment with 4.5" backspacing.
    slowly chipping away at this T5 swap/GT40P install.
  3. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    Basically... im using a makeshift hydraulic kit that i pieced together myself (mostly through rockauto)... im using a push style..
    there's 2 options i found when researching how to do hydraulic clutch with these bellhousings... either a bracket that sets the slave cylinder off to the side of the bellhousing, or mount the cylinder directly through the bellhousing and drill a new hole in the clutch fork. i elected for the latter. I was originally concerned as there were some forums for other cars that mentioned difficulty clearing long tube headers with the bracket option but after getting everything mounted up in there i realized i could've easily went with the bracket kit and saved some headache and time. :huh:
    RMiller likes this.
  4. 71gold
    My friend David located a major vac. leak at the base of my T.B. I corrected it to find that the PCV system needs some love. the PVC valve I installed is way too much. this engine only needs a .090 in. orifice...:slap:
  5. mojo
    With a major vac leak; seems to me the car should have been running/idling poorly. :huh:
  6. RMiller
    Kennewick, WA
    I was looking at building my own too but realized I just didn't want to mess with it. I saw this one would need mods with the scatter shield and wasn't concerned with that until I got the kit. In order to use it my clutch adjustments would be made through the clutch fork window. Since what I have is totally unnecessary for my car I'm buying a new Ford part and calling it good.
  7. 71gold
    I'm guessing the 02 sensor was reading the extra air and adjusting the fuel for it...:huh:
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    Got my gt40 heads back after .040 was milled off. Put the valves back in, cc'd a chamber, and came up with 59. Chased all my threads with a tap coated with anti-seize. I had to remove 2 broken bolts and I dont want anymore of that. I even did my valve cover bolt holes cuz anti-seize is cheap.
  9. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    Had to share this... Loving how these turned out.
    235/60r-15 on the left and 255/60r15 on the right.. all on 15x7's.
    also i got the T5 back into the car and about ready to get the mount installed and drop it to the ground and get my driveline measurement. seeing the rims and wheels gives serious motivation to get this thing back on the road.
    71gold and BBMS18 like this.
  10. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    NICE!!
    Please post a picture when you get the new shoes installed (y)
  11. 71gold
    went out and schooled the Atomic EFI some more...:drive:...:chirp:
  12. 71gold
    had zero oil pressure blinking on my Dakota Digital oil gauge. pulled the sender and hooked up a test gauge. it rear 50 PSI so I was getting oil pressure.
    pulled the test gauge and reinstalled the sender, fired it up and had 50 PSI of pressure...:scratchchin: must be my Ghost...:huh:
    BBMS18 likes this.
  13. RMiller
    Kennewick, WA
    I was tempted to dance with the devil, the Fox body devil that is. Found a very clean, low mile 84 V6 car for 2,000 and considered buying it and putting my go fast bits into it. It was tempting just to have something fun to drive but I went out and spent time with the Maverick instead. Tough to pass on but it would just be another Mustang rather than "ooh, a Maverick, don't see those any more"!
    Door panels usually tell the tale and these look as nice as the day they were born.
    BBMS18 likes this.
  14. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    Here is the worst possible angle i could get in my garage... If it ran i would pull it out and find juuuust the right lighting and angle.. but nevertheless they still look awesome.
    on top of getting the wheels on there... I cut a huge hole in the trans tunnel, got the T5 mounted and driveshaft installed... which i think is going to be okay without shortening... i have about half an inch of play (wheels on the ground, trans fully installed). changed the oil as well.
    next on the to do list: transfluid, hook up the exhaust system again, plugs and bleed the brakes!
    Shorty, mavgrab302 and BBMS18 like this.
  15. BBMS18
    BBMS18 Member
    75 Comet
    That’s one sexy bitch!!!
    noodledood2 likes this.
