  1. mavgrab302
    I installed the new Cold-Case aluminum radiator, the Cold-Case electric fan was a waste of money because 2500cfm is not enough to cool my 306. The temp was between 200 and 220 . I put my Flex-A-Lite back on which is 3300cfm and now the car Runs at 180 to 185 degrees. On to my next project.
    mojo likes this.
  2. mojo
    What Flex-A-Lite you have putting out 3300? I have a Flex that puts out 2500 works ok until I run AC in 90+ weather or waiting for long trains w/ AC running at which point I see 220; I can tolerate that as long as I don't see radiator pucking.
    I been thinking about a Taraus fan, but not really moved to do it yet.
  3. mavgrab302
    I have the Flex-a-lite Black Magic extreme it also has a setting that recognizes when the A/C is on..
  4. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Mojo look into the 90s Volvo fans. It’s the same fan just with out the bulky shroud. You can make your own shroud to fit it.
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    My alternator quit....so it is time for the 3g that has been sitting and waiting for just the right motivation. I am out of space on the battery side of the solenoid, so hunted the junkyard and came up with a part from a chevy truck of some sort.
    jasonwthompson, BBMS18 and Hotrock like this.
  6. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Good choice on the 3G.
    Something like this maybe a better option.
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/152113320053
    This is what I run on my daily driver/plow truck and will be installing on the Comet too. FFDED2C6-5570-44C6-9A7C-4DF0A5B2AE60.jpeg
    yellow75 likes this.
  7. stumanchu
    stumanchu Stuart
    Portland, OR
    Wow. Those certainly carry the mail. The bracket on this Chevy one, with a little alteration, might might slip up behind the solenoid mount. It is starting to look fairly wire populated around there and I am gonna make it look less dense if I can. The next need for power might make me wish for that bus bar though. The Taurus fan conversion and point driven TFI ignition added, at least the 3g subtracts considering the voltage regulator gets to leave.
    BBMS18 likes this.
  8. BBMS18
    BBMS18 Member
    75 Comet
    Always plan ahead and leave room for more accessories (y)
  9. mojo
    Thanks for the info on the Volvo fans. I will take a look at them; I can make a shroud, made one for the setup on the car now. I would have to reconfigure for the two speed fans which ever way I go. Just been lazy about the conversion and had the car on the road to much too really get in a rush to do it.
  10. Earl Branham
    Lugoff, SC
    Everett, get the controller relay that works with the fan. That is what I have
    Everett, find a 2spd relay for the fan when you get it. They look like this and this is one for a '95 model. Hope it works out.
  11. Earl Branham
    Lugoff, SC
  12. NCN
    NCN Member
    Colorado
    1974 Mercury Comet
    Hello all,
    I just joined. Found this post and thought I would share what I did yester
    This is my 74 comet I got. Sat in a field for 20 years. Got it running with help from my stepbrother.
    Oil, coolant, trans fluid all changed, new belts, hoses, starter solenoid, distributor cap, plugs, wires, battery, and cables.
    Carb needs gone through. Tires are being put on today. More cleaning to do, need to bleed the break lines. And a hell of a lot more, but she's alive
  13. NCN
    NCN Member
    Colorado
    1974 Mercury Comet
    Since it won't let me edit to fix the post since it won't take my link to upload the images here's the direct link.
    https://imgur.com/gallery/54SFyhF
    BBMS18 likes this.
  14. 71gold
    :Welcome:...:Handshake:
    NCN likes this.
  15. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Welcome from the Northeast.
