  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I read skipsgrabber’s Crown Vic 12” front disc brake conversion awhile back. http://mmb.maverick.to/threads/crown-vic-front-12-inch-disc-brake-conversion.114417/
    This peeked my interest, but seeing that I have a abundant supply of Ranger 4x4 parts I test fit a Spindle assembly from a 2005 with 11.97” rotor & dual piston caliper on my Torq Thrust 15x7 wheel today.
    09C32296-AB08-46BE-85FC-AC0F694B8207.jpeg BA9AD761-5F64-48D1-B487-196831B09EB9.jpeg 74432E7B-398D-4528-B83E-3439354E15E4.jpeg
    It fit great with no rubbing, looks like I’ll be making up some brackets to mount the calipers on the stock Comet drum spindles.(y)
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Bought a '79 302/C4 out of a F-150 to put in the Maverick. Did I mention I dont know SH** about engines?
    BBMS18 likes this.
  3. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    I installed new control arms and springs a few years ago but the 620 1" drop springs left my car sitting IMG_20190902_142953086.jpg IMG_20190830_114528796.jpg a little high in the front. Not 4x4 high but enough that I was asked many times why my car sat so high. Finally got tired of answering so I cut one coil and dropped it about 2 inches. I also installed Drake hipo spring perches as the rubber in my old ones was deteriorating. Not as nice as roller bearing perches but an improvement over my old ones at about half the price of the rollers. They are decent quality and made in Australia. Tires are 235/60 15. IMG_20190830_114359712.jpg
    mavgrab302 and RMiller like this.
  4. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    Well getting to fall and hopefully cooler weather quickly !! Embarrassed to say after all my winter work....but haven't tracked car since May. Started n let car run for a while on jack stands today.
    Hopefully track time very soon
  5. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Working on getting the '70 running so I can drive it while the '75 is getting the engine swap. Everything was going great until I tried to hook up the transmission shift linkage. The engine/tranny I'm putting is came from a floor shift car, and the '70 is column shift. Tried taking the shifter shaft out of the transmission and rotating it 180 degrees, but the shape won't allow it to move when in the down position, now hunting for the shift lever that goes through the side of the case, but for the column shift (points down) if anyone happens to have one laying around. Had thought about taking the floor shift from the '75, but was hoping to reuse that on the swap.
  6. Earl Branham
    Lugoff, SC
    Received my new ignition switch, so I will change over the lock cylinder, and put a new pigtail on it and see if this is the culprit in my fan problems, and starter problem.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Finally got the battery in the trunk. Works fine.
    Falcenac likes this.
  8. BBMS18
    BBMS18 Member
    75 Comet
    I got a little something in the mail box today for my Comet GT clone.
    3B2BFACC-8E4F-42FE-8C6C-82FF34796D33.jpeg 45BA16D4-4EA4-49A7-A33B-4157DD714828.jpeg
    jasonwthompson likes this.
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    I drove my car once this year. I took it onto the freeway to find out my hood was not completely latched. The good thing is I found out on the ramp and could stop and pull over easily. The bad thing is my hood is folded in the corners and my hinges are probably ruined. Dents in the roof, and the upper windshield stainless.....wouldnt you know, my alternator quit on the way home too. Lol....this year was a bust. I'll be using that Comet hood I got from P&P sooner than I expected. No, it didnt happen today....It is today that I can admit it though.
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Just gave the majority of the money from the sale of my motorcycle to Summit. Thankfully my brother lives in BFE and has a stay at home wife so it's all going there. Hate the thought of it all walking off my porch while I'm at work!
    stumanchu likes this.
  11. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Got the 200 in the '70 fired up. Had to swap shift select shafts from the 240 c4. So far no leaks.:whew:
    The shift linkage was pretty loose as it was missing most of the nylon bushings so bought a collection of brass door bushings in a pack from the parts store. Had to polish a couple of them down on the bench grinder to fit the OD. Now nice and tight! Just put them on a bolt and let them run against the wheel until they were the right diameter.
    71gold likes this.
  12. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Was having issues with idle on the 200. I had put the carb from the 250 on and it was just not working. Between the altitude (7,000 feet) and I assume a larger jet, just could not get a stable idle. So today I put the 200's carb back on and it just purrs. The reason I had put the 250 carb on is the throttle cable, the '70 comes in behind the engine and the '75 the 200 came out of comes across the valve cover. Have to pull the throttle cable and gas pedal from the '75 and install it on the '70. Will figure out something as a replacement on the '75 once I get the 5.0l into it.
    Now some tires, fresh fuel, seat belts, insurance and clean up; it should be ready for a test drive.
    71gold likes this.
  13. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Got my V8 parts to mount my 302...gas pedal, trans cross member, belly bar. And such
    William623, 71gold and BBMS18 like this.
  14. bryson123
    bryson123 Member
    california
    1972 MAVERICK GRABBER
    Not the best photos but almost completely done with the fresh paint for my maverick, alpine white doesn’t get much brighter haha. Has taken 6 months of prep but my dad and I are proud to say we painted it in the garage!
    stumanchu, smegnl, Shorty and 3 others like this.
  15. yellow75
    Tillamook Oregon
    It feels great to be able to do a paint job in your garage and have it turn as nice as you hoped it would .
